0 Members and 491 Guests are viewing this topic.
justawatt
Quote from: AlienGrey on October 01, 2020, 07:58:25 PM
There is this BUT with the EARTH going to the GATE it's dead easy to vaporizer the Mos devise
Quote from: justawatt on August 31, 2020, 12:10:33 PM
base of kacher conneted to ground
Please check the photo I have posted.
See the photo on this page
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg549582/#msg549582
From my exp I have found out when you connect the the kacher to base of the coil nothing will happen to MOSFET.
I have done it my self and the amp reduces and you will get packet pulse what Ruslan has showed
AlienGrey
Quote from: justawatt on October 02, 2020, 02:16:30 AM
The yoke freq is about right or could be up to 24khz, a bit higher appears to be ok like Ruslan says in his video!
But katcher needs staring of gated pulses with push pull wave form ie upper gated pulses on negative off
and on the next push pull half of the wave your gated katcher pulses need to be negative going unless your just using
the one side or the push pull triggering (note the 16khz is to low to pass through the grenade but the 1.6 Mhz acts as a carrier
according to Ruslan!
As the 1mhz6 is used to modulate the grenade as in colors moving wave form.
it's all in or on colors erratic thread and Russians video again on colors thread.
PS some where a second inverted 16khz is produced and is inverted to create a standing wave in the grenade
so a lot is going on infact some have said a spectrum annaliser is needed to see exactly whats going on.
But you need to translate Ruslans video to understand him and what he means.
Please note I originally built such a device and with katcher (glorified Tesla coil) I didn't get it going
most of it got slung in TK's video right at the end he says it's all in the coil module he also says he removes it
on each demo and destroys it at the end of the demo (wise guy) and has to build a new one next time round.
Still we live and learn by our mistakes but as time goes on the winds of truth finds it's cracks of entry.
NickZ
Quote from: soliman on October 01, 2020, 06:46:31 PM
hi, AlienGrey.
Could you give us a better copy of this drawing?
that can be clearly understood ?.
I am currently working with the ground wire
a few days ago I had a good interaction with the earth
but I changed some cables and I lost it.
could you or someone give me some help to get  back
the interaction with the earth?
   Soliman:   The earth ground wire should be 37.5m to 40m long. It should be connected to a copper rod that is buried deep into the ground.   If you are using a simple Kacher circuit, the ground wire is connected to the transistor emitter, not to the base, as is done with the controlable Kacher circuit. You can check that with the schematic below, the ground line is connected to  the Kacher's emitter.
   You will only see an interaction between the HV circuit, and the induction circuit, along with the ground, only when both circuits are in sync. Otherwise, there will be no effect noticed when connecting the ground line up. Only when the device is in sync,  with the ground connection, will there be any increase at output.
   Below is the simple Kacher circuit that I use. Same circuit that as was first used by Ruslan, and was built by Oleg, his circuit builder. It was used by Stalker, and Adrian, on their self runners.
  This is the TL494 induction circuit schematic, that I use, below.  Hopefully we can get back into making these circuits work, instead of fighting between ourselves.
   NickZ
AlienGrey
Nick
Still happy days on the beach man ;)
NickZ
Quote from: color on September 01, 2020, 07:05:55 PM
I'm very curious about what AlienGrey is.
Since we have begun a background investigation, the identity will soon be revealed. 8) ;D ::) ;D
   AG:  I would be careful with dealing with "Color".  SHE may be out to get you, and everyone else.
Seams more like a troll, to me.
   Who is the "we" that she is talking about?
    So, let's help keep this thread clean of the BS that has taken over some of the threads, lately.
   And, get back on track, after a long pause.
    NickZ
    PS.  Apecore:  Welcome back! There is still plenty of room for you here, now that Hoppy flew the coup.
