0 Members and 73 Guests are viewing this topic.
NickZ
  AG:  So, where have you been the last several years. Out in right field...   Maybe ask Jeg. He has more patience with your eternal non ending questions.
NickZ
AlienGrey
The problem is this you haven't exactly got your own device to work so you have no room to try and make feel bad about my self.
One thing you burbling on about the VW wave form ie the Russians speakers showed a 1 to 3 lock wave, the problem with that is
the TL494 used in this design wont work as it only has push pull and none of the scope shots show a multi frequency device.
all you have is a HF purser (nano pulsar) Ah! but your device doesn't have that facility. Your using it as some sort of none standard
HF mixer, and you can't understand why it doesn't work. So there you go  ;D ;D
PS yes I like to ask questions, They don't like questions, it has got me kicked off for my trouble of learning they think i'm testing there ability
If you don't ask you don't learn and it can lead to sorting the wheat from the chaff!
Respectfully AG  :o :o
conico
Hello guys,
There are some similarities and differences between Kapanadze's and Ruslan's systems.
High voltage to Ruslan's system is a single frequency signal. at Kapanadze's system it has a spark. That spark gives several signals with a wide spectrum of frequencies. Only a signal of a certain frequency is used in its system.
At Ruslan can be a signal in grenades and in the double frequency  in inductor or the same frequency signals. This does not matter. It is important that must be a 20-90 degree phase shift between signals. At Kapanadze the same 90 degree phase shift between primary  and secondary. This means that the primary has influence over the secondary but the secondary has no influence.
r2fpl
Quote from: conico on November 01, 2020, 01:20:18 AM
This is not the scenario. The two coils either see each other or not. When there is a phase shift, the exchange of the magnetic field decreases or increases.
In this case, the coils always see each other or not. That's not what Kapanadze says. I only know one possibility when 1coil works on 2 but 2 doesn't work on 1.
It's hard to think of, but it is possible.
r2fpl
If Dally was Kapanadze's family, there is a good chance he showed the real device.
His last words are: "Akula and others have already sold our technology."
From then on, he has not published anything until today. What happened to him? somebody knows ?
Ruslan claims he repeated his device several times and confirms everything. There are even movies you know what to look at.
