0 Members and 135 Guests are viewing this topic.
NickZ
  MenofFather:
  SR mentioned in his video that a strong noisy spark is not needed to make his system work. A small relatively silent spark seams to work fine.
   The best part is that his device only needs a small 9 to 12 volt battery to activate it to start, just to charge the start cap. NO inverter, no commercial induction heater components, no expensive battery needed, either. And of course it's self running, once started.
It also, doesn't need the 220v input like the TK or Akula devices.
And  the SR device looks to be non-shocking, even though the bulb gets very hot.
  If we could only figure out how it really works...
T-1000
Quote from: NickZ on August 31, 2013, 12:05:27 PM
   T-1000:
   Why is this replication a success? It is barely lighting the bulb, ferrite rings and all.
How much input power/to output power?  Self running???
I don't understand, please explain.
The first attempt barely lit the powerful bulb, yes. Later one lit better when HV source is on - http://www.youtube.com/watch?v=R7bmwpyNkok
Please pay attention to power consumption of inverter before powering on spark gap and after. The single wire from spark gap won't make such difference without anything caused additionaly. Also it is not ideal circuit there because it is only one wire passing through inside of coil. There is space for big improvements leading to Kapanadze/SR193 solution.
The effect is there and this is main thing to pursue and exploit...
P.S. The discharge needs to be weak just to stimulate process.
magpwr
Quote from: T-1000 on August 31, 2013, 11:45:58 AM
If you want to pursue SR193 circuit you need to understand how it worked. See the wire through inside tube made from ferrite rings? Without this it is just inverter. Now please see these successful experiments: http://www.youtube.com/watch?v=xuKiLjv0UqY , http://www.youtube.com/watch?v=qmirRN3O6Ko&list=PL1B521AB8CEB7C605&index=95 and http://www.youtube.com/watch?v=FNuoyPr4_NA&list=PL1B521AB8CEB7C605&index=96
This is what I think makes it self run due effect caused and utilized in full potential.
P.S If you get effect on your table please have Geiger counter ready as it might be NMR most likely.
Hi T-1000,
Thanks for dropping by.It's 1am over here.
I've seen those video which you sent the link.
The most recent post you just sent to me contains interesting video.After that video ended i bump into this video shown below which i can't spot the earth wire and yet the bulb is lit.
http://www.youtube.com/watch?v=wAmDpqhvxZE
Regarding Geiger counter the correct way to use is within a room but not near device within 1 meter as it will interfere with it's internal circuit.
There is post where i mentioned about a guy whom create 50000Amp transformer in Kapanadze topic earlier today.He have done a crazy experiment with X-RAY tube .He used GMC-300 Geiger counter
within the room to prove there is radiation.
Regarding SR193 i think many people have made big mistake in winding too many turns for the primary input or too less for the secondary output.There was no proper stepping up voltage like winding for 9volts step up to 220v for example.
I observed no other video attempt to create a loop back using a simple step down transformer 220v->10v or 12v even after the bulb lit brightly.
NickZ
  Magpwr:
  Your last link is supposed to be a fake. This is what has been said, I don't know, but...
   T-1000:  Yes, there is room for lots of improvement, as the effect may be there, but no success on that device, either.
  I understand what you are saying, but the best example of using a ferrite core is the last video made by Igor.  http://www.youtube.com/watch?v=LCqX5Y6jP3U
  There are no known working replications of the SR193 device. Many have tried, and many have failed.  I'm hoping that will soon change, although some years have gone by.
  I found a Tv flyback in my junk pile. Does anyone have a single transistor working flyback driver that can be used for an induction oscillator to be used on the Akula device, instead of my using my Joule Ringer circuit. As it seams that the flyback can output more HF than what I'm currently using.
MenofFather
To use higher frenquency, you just need less turns. But joule not have LC resonance.
This circuit can be used and for flayback and for induction heater. But it not tested, but I made many similar circuit, and it probarly works, if no, then capasitor add only to first coil and then maybe it can not work on inductor heater, if no core.
