0 Members and 416 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on December 14, 2020, 02:08:23 PM
https://www.youtube.com/watch?v=ZMHO0X4uSYI
T1000 Re Akula's drawing in your youtube pointer ' can you see what he is drawing
and is it tread related?
Also have you come across a project called the bullet? it looks like it's gone underground after
Mr Putin's pruning episode.
It had an awful lot in common with Ruslans device.
AG,this are synthetical circuits,well :when You understand such well
https://en.wikipedia.org/wiki/Gabriel_Kron
and https://en.wikipedia.org/wiki/Dennis_Gabor their branch !
" the mills and boon scrap book"s ? EE  linear algebra, multilinear algebra, and differential geometry
Des-culpe me,Gran-Mestre !
https://www.google.com/search?client=firefox-b-d&q=human+brain+neuronal+circuit
Brain up I,ROM and Brain down II,RAM
....... ,these 7  points I donate You ! To fill in right ,above !
Adeus
OCWL
p.s.: R.A.M. the yes/no moments the male/female decisions
        R.O.M.  the yes/no moments the male/female decision/
      synthetical cerebral circuits  ' and the spice': motivation !
      Dale Carnegie ,example : the male crowed and the calw
      one woman gave the the calw appropriate solution,? !
      Likes 5+D- FE U ? ;) Are You appropriate ? A.monchichi + B.  Tamogotchi :
      who is who ?
      Master & servant
(Y)in power(energy)     or  (Y)an power (energy) or (Y2)inan power (energy)
T-1000
Quote from: AlienGrey on December 15, 2020, 05:58:38 AM
The Akula's own explanation how device works is thread related.
And in his words it is like in magnetron. The electron emission on resonanting receiver makes it work.
P.S> This is same method as in TPU devices or Testatika...
NickZ
   "Electron emissions" ???    What is that? You mean the HV and HF pulses (emissions) from the HV Tesla coil circuit?
    What would Tesla say to that explanation?  Concerning "electrons"...
    None of these explanations have resulted in a self running device. Such as the use of the "spark gap", that Akula had mentioned to T-1000. But, T could did not show it working to produce OU, as Akula had said, that it would be easier than using some other pulsed circuits.
    The Lithuania tests was another case of measurement error. Which can not be replicated, even by the original team.    Someone should have woken Wesley up, when they saw the 1000w bulb light up, from a 10 watt input source.
    And both Chris's and Captainloz's false OU devices are also just a waste of time, resulting in more measurement errors. As I had mentioned previously, which was obvious to me, just by looking at the weak output.
   I hope that Ramset is listening to me, this time. But, I don't expect that to happen, as usual, as he is always looking to bring in supposed OU inventors. Which up to now, have all been flops. Perhaps he should just leave well enough, alone, and focus on making something that work, himself.
   And yes, I trust my own eyesight, before any iffy tests on scopes or other test equipment. As false tests results is all we ever had here.
    NickZ
itsu
Quote from: Jeg on December 08, 2020, 01:46:13 PM
Justawatt wonderful work! ;)
Guys, can someone please measure the peak to peak voltage across the 3-turns secondary when in resonance?
Thanks
Hi Jeg,
i still have my Grenade / inductor and drive (lossless clamp) yoke with the 3 turn coil etc., so i put it together and connected the 0.47uF Wima cap in series with the inductor, on the 3 turn coil.
Voltage on the Lossless clamp MOSFETs was 24V driven by the TL494 at 15V.
Series resonance was at 15.4KHz with 1KV!! sine wave across the Wima cap.
When measuring the 3 turn coil only i got the below signal.
So a square wave like signal deformed by the high sine wave resonance signal of the series LC, but relatively low peak to peak voltage (22.5V).
The Grenade coil was not connected to anything, also a 16 turn secondary on the yoke was not used.
Let me know if you want me to make some more measurements.
Regards itsu
