0 Members and 171 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on December 16, 2020, 11:02:27 AM
itsu: If you are stilll playing around - put capacitor across output of grenade and try to tune to double LC frequency after yoke which you get running in resonance. Also have load attached to it all the time. After it runs stable start varying input voltage until you get unstable amplitude waveforms. Then see what you can get on output after hitting with spikes from Tesla coil few degrees before top of amplitude (which also have tight input voltage range).
Cheers!
wish i had a 20 pound note for every time i told them about that instead of abuse  ::)
justawatt
Quote from: AlienGrey on December 16, 2020, 10:41:09 AM
What are the video's point me to them
I added you in skype .
It's not In youtube .it was send to me by a Russian group
I will send them to you there
itsu
P.S> The output operating frequency have to be one of harmonics when peaking to the ground.
P.P.S> These instructions are after all observations what eleeexwsergey did to his device when tuning. Also in line with akula explanations.
Cheers!
Hi Arunas,
i just have some bits and pieces which i put together for Jeg to make some measurements on the 3 turn coil.
There is f.i. no ground attached so i can make measurements on this 3 turn coil without causing groundloops etc.
In a real device with proper grounding, this 3 turn coil would be impossible to measure due to the grounded scope lead, only when using the differential probe method.
But i have no intention to reopen this experiment for the time being.
Regards Itsu
NickZ
   Differential probe method?   Please explain. ;)
   NickZ
AlienGrey
Quote from: justawatt on December 16, 2020, 11:31:12 AM
only 2 are in some sort of Russian dialect the rest are in German  i have an English copy of the Ruslan video some where
i will have a look and send it the link to you
