0 Members and 412 Guests are viewing this topic.
NickZ
  Nightmare:
  That thought about Akula gave me sweet dreams, I hope that it's true.
  Welcome aboard!
                              NickZ
Grumage
Dear magpwr.
You are a quick learner!! Indeed the SR 193 device is, in it's basic form a step up transformer. But something special happens to the core at the right frequency. I had a lengthly chat with T-1000 yesterday and then I went to my....... lab  :) (back room)!! to have a play.
I basically built a 1:1 ratio transformer with a Ferite ring core. Now what was supposed to happen was that with a 12 Vac input and a small 12 V bulb on the output, when a HF HV pulse was applied to a split Copper tube running through the center of the cores the bulb should have got brighter. No such luck! nothing, bulb at the same brightness.
Now here's the thought? Does the core have to be of a specific Ferite make up? Is this the reason why our Russian and Eastern European friends have the success? I don't know the answer to that one!!
So thinking another way round, you mentioned that you were getting some Barium magnets made. Can your supplier make some unpoled Barium Ferite rings?? BTW for your Floyd Sweet device I would suggest you get some of your slabs un megnetised. To me it seems silly to get them to magnetise them and then you have to demagnetise for the conditioning process!! This may also be an NMR device ;)!!
And another BTW I followed your notion of Barium Ferite having a very high resistance. Every Ferite Rod, Ring and Magnet I tested all showed the same, no reading, so I am not so sure your test is a definitive one, or did I miss something??
Well that's enough for you today, I look forward to reading your remarks.
Cheers Grum.
NickZ
  Dear Grum:
  The Ringer circuit that I use gives about 1500 volts, as well as hefty shock. This would not happen (the shocking aspect), if there was no current output, which is due to the use of the ferrite bead core. So, there is some current output in my ferrite core as well.
  The type of ferrite can vary in its ratings, and the most expensive high perm ferrite, of course is going to light the bulbs brighter than the low perm ferrite ones.  The better ferrite can go up to about 80.000.
  Just what kind of ferrite SR, or Igor used, is unknown but I can ask Igor, if that info is needed.
  However when I connect the 2uf cap to the 3 turn yoke coil, in series with the 12 turn resonator coil, it does NOT shock me, but does still light a florescent bulb. Which needs several hundred volts to light a 65 watt CFL bulb (normally), and it will also light a neon bulb. So, something different to normal induction is already to be seen.
   Akula mentioned that the use of an iron wire, or iron core transformer would improve his devices output.
  I feel that the first step is to have a induction oscillator that can heat metal. Then to see how to adjust the two different types of high voltage and high current heterodyning in the yoke, or toroid, so that the 3 turn coil's output is low volts, but high amps.
Then to place the choke that goes inside of the air coil, which may possibly also be wound on a ferrite core, and see which cap is needed to make the choke into a proper tank circuit.
  That is what I'm up to, but need the right parts to do it properly, which are still unknown to me at this time.
  Hopefully we can get in touch with Akula, to see about how to go best about it.
  T-1000 mentioned that Akula was willing to help us, previously. Maybe still?
  I'm sure that Akula spent many hours, days, and maybe even months to get to where he is currently at now. This could possibly be avoided by us, to some extent, with a little help from him.
  This is the ferrite core that I'm going to be using as the choke (second pic below), only without the outer winds, only the inner 400 turns of magnet wire, connected to a tuning cap.
  Or also the air core one that's in the choke on the first pic below.
magpwr
Quote from: Grumage on September 01, 2013, 03:32:15 PM
Dear magpwr.
So thinking another way round, you mentioned that you were getting some Barium magnets made. Can your supplier make some unpoled Barium Ferite rings?? BTW for your Floyd Sweet device I would suggest you get some of your slabs un megnetised. To me it seems silly to get them to magnetise them and then you have to demagnetise for the conditioning process!! This may also be an NMR device ;) !!
Cheers Grum.
Hi Grumage,
It's 7:30am Monday morning
There is something i'd believe you have left out which is related to resonance.I'm finding this device SR193 have a strong relationship with "this device" which i have easily constructed around 1 year ago.
I'm unable to get the link to youtube video at this last minute there was 2 users whom have done this experiment.I merely replicated with success.
That 2 videos in internet merely use 1 battery and create a circuit to resonate with the tube.One the 2 videos also used screwdriver inserted it into copper tube and there is voltage to lit led even on so called 0 resistance.
Let me describe the device in words sorry.Not sure where i placed it in my drawer to take a quick photo.I'm little rushing for time now.
The device is merely made up 7 or 8 toroids on a small copper tube\pipe insulated from the small toroid.In that tube i merely put a straight 18AWG copper in it.
This is the fun part.If you apply the right frequency i think mine was around 2KHZ can't fully remember.On the 1 strand of copper (in the center of copper tube surrounded by toroids) voltage becomes amplified".
Now this is just theory upon using HV transformer i suspect upon adjusting and "hitting the resonance frequency of toroid with copper tube in it voltage would surely be amplified".But remember in that 2 video i have mentioned above in the experiment there was no step up coil surrounding the toroids.But in SR193 there is.
I just found the youtube link base on what i'm talking about. ;D
https://www.youtube.com/watch?v=71vtcl-G4dw
Other thing i recalled i heard or seen somehwere in a Kapanadze video or forum the ferrite to be used is "2000u" .I suspect this is more suited for 50HZ <1MHZ.If you take a look at ferrite material spec easily found in internet.
Nightmare_T34
The meeting with Akula didn't occur , sadly...
