0 Members and 417 Guests are viewing this topic.
itsu
There is a lot of talk about this "dancing wave" and "fish-like waveform" lately which could/should be the secret to the Ruslan device, both here and via PM's.
This video is showing how these waveforms can be created, presented by Justawatt in post #22809:   https://youtu.be/FBAKLoOXv34
They use a push/pull kind of setup driving a inductor/grenade like coil combination.
The difference is that the push/pull is not driven by a TL494 (single frequency) but by a 2 channel FG set at 2 frequencies a few (K)Hertz apart.
This creates a zero beat effect (https://youtu.be/Gwo092k4N2U?t=48) causing adding and subtracting the both signals when mixed and thus the fish-like signal.
I could easily show that effect using my TL494 driver, Yoke, Inductor and Grenade, but instead of using the TL494 single frequency i use my dual channel FG to drive the MOSFETs with 2 frequencies slightly apart, see screenshot.
Video here: https://youtu.be/yker3GIvchg
Why others see this fish-like waveform using only a TL494 (single frequency) could have something to do with oscillations in the TL494 circuit causing the both TL494 push/pull signals to slightly go offset or delayed thus presenting 2 different frequencies again with the same effect.
Stiffening up this TL494 circuit (0.1uF decoupling ceramic caps directly across its plus / minus leads on the chip) etc. could prevent this.
The question is if this then will not KILL the overunity effect it suppose to have.
This oscillation / feedback in a circuit is very hard to replicate, so it is up the ones having this fish-like waveform to either use it (overunity?) or battle it by decoupling.
Why does Conico see this same fish-like signal using a single channel FG and no mixing?
I was not able to do that, so i guess it must have something to do with the equipment he used, like his FG is somehow mixing internally 2 frequencies and present it to
the inductor/grenade or... there is really something happening inside the inductor/grenade like standing waves or whatever that is causing this, so more tests are needed.
Anyone else seeing the dancing wave while only scoping the Grenade and driving the inductor by a FG (single channel) in resonance?
Regards Itsu
NickZ
   Can some one show how this fish form wave/dancing wave thing has anything to do with OU, or self running???   Or are we barking up the wrong tree, again.
   NickZ
N20Wolf
Quote from: justawatt on December 20, 2020, 08:47:13 AM
https://drive.google.com/drive/mobile/folders/1zoGipNcPazprWeMgVb7UDIYwyu3fO_OL
This is the link..you can only see it to download it have to get the grand from them
Thank you! but how to find the author of the scheme?
NickZ
   "Why does Conico see this same fish-like signal using a single channel FG and no mixing"?
   Perhaps, it's because he has a difference on his push/pull circuit, and both channels are not seeing the two primary inductors as not being exactly the same, on both primary coils. An imbalance in the circuit, etz...
   We must keep in mind that the grenade's push/pull device runs at around 15 to 19KHz. And we know that different frequencies (higher or lower) can cause different waves forms and results. But, does this really lead to something anamolous? Or not...
   NickZ
itsu
But he is NOT using any push/pull circuit, just a single channel FG driving directly the inductor and scoping the Grenade like i showed here:
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg554039/#msg554039
The hype is that this dancing wave is the missing secret from the Ruslan device.
Adding kacher spikes or nano-pulses ontop of this dancing wave causes the OU, at least that is how i understand it all.
Itsu
