0 Members and 256 Guests are viewing this topic.
NickZ
Quote from: conico on December 20, 2020, 12:11:08 PM
Hi Itsu,
My FG has two channels but I only used one I'm sure I used only one frequency. You made a mistake, you just had to give a signal on the inductor to start from 1500Khz and go up to 1650Khz to see where the grenade signal dances.
You use two frequencys but it's work with one too because you have two coils and  one can be a mirror for the  other one.
I don't use load or you can use a Higher impedance load.
   Does that mean that you can't get the dancing wave at 15 to 20KHz, like the normal grenade inductor frequencies.
  What positive results will happen between 1500 to 1600Khz? Other that dancing waves...without a load.
  And what will happen when the Earth ground line is connected up to the dancing wave frequencies. It will change things...as well as adding a load. All these things will change the running frequencies.  Or not?
   NickZ
conico
You will Know Tesla frequency first and the push-pull frequency after.
itsu
Quote from: conico on December 20, 2020, 12:29:09 PM
In your case , something distroy the mirror betwin coils.
You can do something else. Use push-pull with TL494 on inductor and the scope on grenade  Someware the signal from grenade will dance. Go from 10Khz to 60-70Khz
I tried that too, large frequency range, low voltage on the MOSFETs all the way up to 30V, but it stays stable, but i will try some more tonight.
But while playing with my TL494 / push-pull circuit, i was mimicking some feedback / oscillations on the TL494 circuit by touching with a metallic screwdriver some of the pins (pin 6), and was able to create this dancing wave.
So i strongly believe that MOST of the dancing wave signals people have seen are coming from inadequatly shielded / decoupled TL494 (or any PWM) circuit.
See (hear) short video: https://youtu.be/ro3e1gevHAw
Itsu
NickZ
Quote from: conico on December 20, 2020, 12:36:51 PM
   I already know the Tesla frequency and the push pull frequency.   After what? Can you answer the questions I asked.
   Thanks for the video itsu, it does seam to be some kind of interference wave form, instead of something actually useful, from what I can see.
   Even placing one hand over the TL494 circuit is enough to change things, for me, when everything is going, including the Kacher impulses.
    NickZ
conico
I believe that bulb destroy the mirror signal  Inductor give a signal to grenade and like a mirror grenade sent back a signal but not so strong. That why we see dancing signal in amplitude
Your setup is exactly like mine setup , except the bulb. Will you try without the bulb and no load at  all?
