0 Members and 77 Guests are viewing this topic.
magpwr
Quote from: Hoppy on September 03, 2013, 03:30:31 AM
I would like to see an extremely clear photo of the earth connection to the central heating pipe.
Hi Hoppy,
Upon checking the energetic forum there is no other photo of SR193 uploaded around Year 2010(around 3 year ago OMG).
In fact i was surprised to see clear photo over there as if the person whom created the device was in the forum...or knew the creator of device somehow...hmmm
magpwr
Hi everyone,
Today i have just completed purchasing 2.5mm  multi strand electrical copper wire for SR193.I had to buy the 100m version since if i just wanted the 30 meter it would have cost more.
For those whom are planning to construct please take note of the toroid core you are getting and taking note of the internal diameter.
To get copper pipe of right size is actually harder.I actually overlooked this part.But i was lucky there was just a small piece of copper in a shop which fitted my toroid leaving with just 2 or 2.5mm gap.
For pvc it it's impossible to get a perfect size .If my toroid is around 4.3cm the next closest is 5cm ID pvc pipe.I do hate to give such a big gap.
I may consider finding cylinder shape cardboard just to fit toroid.
Copper pipe may or may not be used in experiment depending on output and other factors which i have mentioned during the last 2 days(maybe).
It's nearly 12midnight here.
I merely did a quick test with toroid with copper pipe configuration base on this video.
http://www.youtube.com/watch?v=dkcggzRIFnY
Thing to take note the current only flow one way on the 1 straight AWG wire placed in the tubes.
What i'm trying to say although multimeter in A/C mode see voltage like 0.465volts.DC mode no reading.
The bulb only able to be lit  1 way even it appear as A/C.I have not tried with my scope yet.I'm not sure if this helps to ring a bell  for some"related to preventing back emf" found in some article somewhere.
If the output is retified and with caps the voltage is 13.xx volts low current.
If the output is shorted the load on battery is mere extra 4mA.Does this sound familer with hv via spark gap with some loading.
Hoppy
Quote from: magpwr on September 03, 2013, 04:18:41 AM
For those that cannot find a suitable sized copper pipe, a length of copper wire will serve just as well, with a plastic tube or sturdy cardboard tube used to mount the ferrites on. The ferrites just serve to mix the waveforms on the HF & LF wires running through the centre of the ferrites by induction. As I see it, it is not absolutely necessary to wind coils on a tube over the ferrites, although this does act as a convenient winding former. Also, there will be a certain number of ferrites required to obtain optimum induction, so don't buy too many at once as the specified 2,000mu toroids can be expensive.
NickZ
  Magpwr:
  I am still active in the Laserhacker.com forum, and especially in the Joule Ringer thread, along with the cross-over thread. On the cross-over thread there have been several interesting replications done, by myself, along with Lynxsteam, Gadget, as well as some newer test and videos done by LS himself. It is still an ongoing thread, and not a done deal at all.
  My experiments showed a self charging circuit, which charged its own run battery for over two weeks, until the battery failed, as it was only a non-rechargeable D-cell. It would discharge to almost nothing, then recharge it self to the starting voltage of about 1.2 volts, then discharge again, this went on for quite a while, although not much light was produced from that circuit. Still interesting though.  Picture of one of my cross-over circuits below.
  The video of the small Kapanadze circuit was not meant to be showing his newer coil working, only the flyback circuit, along with a previous coil.
  He has 10 years of experimentation on free energy devices, and over 400 videos under his belt, and is not known as a fake device creator.
  His coil is similar to what the newest Kapanadze videos are showing, as well as what Igor Moroz, SR and other with somewhat similar devices have done.
He is not telling all, like many others that have working units.
  One of my cross-over devices (Below), running on a 15 year old dead D cell, after two weeks just before it died, from old age, if nothing else. It is a self charging circuit. And Gadgetmall had one of his circuits runaway and blow up, from too much current.
The mistery of this type of circuit is not yet concluded. You might want to check the cross-over thread now, and see the newer LS videos about this device, if interested.
magpwr
Quote from: NickZ on September 03, 2013, 11:59:13 AM
  Magpwr:
Hi Nickz,
Nice work man.Keep it up.
Try to use 10,000uf caps like laserhacker did instead of using battery or nimh which already have existing internal high discharge rate 20% per mth unless it's the eneloop series. ;D
