0 Members and 79 Guests are viewing this topic.
Magluvin
What I had seen is that the 2 windings are still bifi and can resonate, even though it is open ended. Similar to the way an AV plug works by charging via 1 wire from an open ended transformer secondary. And actually you can use the av plug, 1 on each end of the open ended bifi and charge 2 caps. I believe I was in the energy amplification thread on this subject, but dont know how far back.
My first reply with the diagram is the last one on the previous page.
Mags
Magluvin
looking for the diagram now that I had made that expanded on this idea..  Just found it. Using a trifi coil.  Instead of dumping the input pulse into a low turn primary, I used the field collapse of an inductor to charge as shown. Being there is no conductive load, only capacitive, it accepts the full dump from the collapsing inductor and does it quite well. The output to the far right transformer was just the idea at the time in this diagram and went on with av plugs from there and had to set it on the shelf for reasons I said in my previous post.
Mags
Magluvin
My reasoning for using the field collapse as the input pulse was in reference to the Tesla Igniter pat circuit, as it is a very low input if the inductor is large and the collapse is high voltage dumped into the trifi.  Dont know where I put it here but I had done comparisons of traditional points spark circuits and the igniter circuit. The traditional circuit required near 70 to 80 watts and the igniter circuit was about 1 watt to get nearly the same spark output.  Here are my YT vids on the subject
https://www.youtube.com/watch?v=b4aHl8JL2PI
https://www.youtube.com/watch?v=aNLUGqH4W1c
https://www.youtube.com/watch?v=WkdIDbiCxTM
https://www.youtube.com/watch?v=bgDbBsA15C4
https://www.youtube.com/watch?v=IafARcXrTs4
Mags
AlienGrey
Mag luvin, those circuits of yours arn't they a bit like pie in the sky ?
how do you wind them, number of turns, spacing and what not ? (i notice your update all 1Henry)
that will cost a fortune in copper wire and rather bulky, that now leaves the problem of how its wound.  ::)
the other thing the biffilar thing winding them on top of each other, close knit
the other problem with biffilar is it's in phase  ;D but there is a trick D Smith used in his windings
and it might strip the magnetic field (cancel it) but if you read your history of the masters
the effect is lost on entry better to make use of it where you can.
NT gave Marconi EM RF tech to Marconi because he knew it was useless
now you have liar twats like the American military junta saying radio waves cant go faster than light
and they would rather destroy the planet than let things change.
Come on you have seen the MR Preva coils Chris Sykes keeps burbling on about he as a very strong point there.
The only thing to watch there is the ratio between coils as it impacts strongly on the frequency.
PS all this  info is in this thread!
SIL
Magluvin
