0 Members and 623 Guests are viewing this topic.
T-1000
Quote from: forest on January 29, 2021, 06:00:31 AM
According to picture of ancient health symbol we should have free energy if pushing at resonance a ferrite rod from one end while connecting the load to the other end with bifilar coil not closed acting as a capacitor. is that correct ?another example would be ferrite tube composed from glued choke cores - primary on top pushed at resonance (with parallel capacitor) while inside again bifilar not closed coil.It would be fantastic if somebody could test it....
The way we did get induction going was 2 coils as capacitor for main circuit + avramenko plug charging capacitor then having sudden discharges for induction. And that was done way back in Lithuania experiment - https://www.youtube.com/watch?v=hDXEC6GeGA0
Cheers!
color
I have something I would like to ask my members.
Can the circuit diagram below be patented?
It is a combination of a typical amplification-transformer and a Tesla-kacher.
If Kappanadze said that the circuit diagram below would be patented as it is, would the Patent Office permit it?
Kapanadze has only the role of combining amplification-transformer and Tesla-kacher.
Would this also become a patent? ;D ;D ::) ::)
AlienGrey
Well Patents by the sharks, well if it's been published well before its patented you can tell them to take a running jump!
If your in touch with Ruslan why don't you ask him for his definition on what he means,
how the Katcher runs at 1.5 or is it 2mhz when there is this scope shot ?
Since some of his new videos you don't see a katycher  ;D ;D
color
AlienGrey
The below Romanscope experiment using a microwave transformer belongs to the single-wire transmission technology.
It is not strictly a single wire transmission technology.
MrRomancorp
https://www.youtube.com/watch?v=ET7CrFDs6fY&t=0s
This is an experiment in which Romankov confidently evaluated the Kapanadze-generator.
Similar to Wesley's Lithuanian OU.
https://www.youtube.com/watch?v=nmmzKKNULVo
юра сам
там где он показывает направление магнитных потоков на 5.10 минуте. от либо говорит ложь либо не знает. магнитный поток наведенный проводником не может вращаться не вокруг этого проводника. а он показывает что проводник в окне сердечника сам по себе, а его магнитный поток вращается внутри сердечника сам по проводник в окне сердечника сам по себе, а его магнитный поток вращается внутри сердечника сам по проводник в окне сердечника сам по себе, and в таком варианте который он показывает и о котором говорит магнитный поток в месте столкновения потоков, потоки выйует из сердечника пройдет через середину окна и вернутся в сердечник с обратной стороны и каждый в свою или через свою катушку завершит свой круг вокруг проводника породивший это кольцо магнитной линии . Романов любит пурги навести что бы не показать то, что происходит на сама деле. мне нравится его КАК БЫ. не как на сам деле, а КАК БЫ. да еще разделить это "как бы" на четыре части, потом померять длинну проводника в котором волновых взимодействий вообще не может быть исходя из длин волн на этой частоте и ими можно пренебречь и еще посчитать на каких частотах будет четверть волны. которая в этом тр. ни с боком ни с припеком. и данный принцип работы этого трансформатора основан не на взаимнотействии волновых процессов, а куна магнитных связях и с с умным связях и с с умным связях. не хочешь людям рассказать реальный принцип работы тр. в режиме преобразования энергии и врежиме СЕ, так хотя бы не заволи людей в заблужение. , это не поряточно.
Alex Kuzmin
на схемах принято начало обмоток обозначать точками. При таком соединении будет КЗ. Надо было соединить обмотки последовательно. Тогда,если обмотки одинаковые, на выходе будет ноль, если разные, то разность напряжений. В трехфазном трансформаторе перекос фаз не приводит к смещению нейтрали, просто появляется уравнительный ток в нулевом проводнике. Фаза напряжения во вторичной обмотке смещена на 180градусов относительно первичной. Насчет смещения фазы и асимметрии полуволн это Ваша фантазия(проверьте сами осциллографом). В трансформаторе передаваемая мощность определяется магнитным потоком и индукцией, и всегда справедливо утверждение, что сумма векторных произведений напряжений и токов в первичных обмотках равна сумме таких же произведений во вторичных. А то народ подключает вольтметр и амперметр, видишь, вот сила тока уменьшилась. А если подключить ваттметр то сразу все станет на свои места, поскольку он учитывает сдвиг фаз, который тоже изменится.Сколько раз давал себе слово не критиковать людей, не заглядывавших в учебник по ТОЭ, где расписана теория работы таких устройств и для неверущих все подкреплено формулами , откуда что берется.Потому что в ответ чаще всего слышишь типа сам дурак. Интернет такое позволяет.
And I have seen a lot of similar experiments by members.
https://www.youtube.com/watch?v=S_URR6Bk9cg
GFusion Core
https://www.youtube.com/watch?v=IdMVSiX2V7k
https://www.youtube.com/watch?v=vTCaF7R4Z-M
Spigel Branimir
https://www.youtube.com/watch?v=ARCLD3qgjmI
MrSiliks
https://www.youtube.com/watch?v=v0UXhKCWPuA
Igor Moroz
https://www.youtube.com/watch?v=fVj08I_A_KE
Ingener99
https://www.youtube.com/watch?v=YsGwdPqCpX0
Konstantin Lagutin
https://www.youtube.com/watch?v=ozGwb0glcXg
vasmus
https://www.youtube.com/watch?v=MzsvSHiRyvo
AC requires earth-ground.
I did not do it, one woman did it with two heavy swords. I told her keep your back straight and just swing them in front of you horizontally in opposite directions.
She and the chair were pulled forward.
I can't believe this simplest of ALL natural phenomena is still not recognized.
Good luck.
https://www.youtube.com/watch?v=4b69koOYry4
partzman
Quote from: color on January 30, 2021, 04:50:04 AM
The basic answer is no.  What may be patented is the function of the circuit diagram if it is novel.  Also, the idea that if something is published say on one of these public forums it is not patentable is incorrect.  The international patent agreements between nations honors first-to-file not first-to-invent as it was in years past.
Pm
