0 Members and 163 Guests are viewing this topic.
Hoppy
Quote from: NickZ on September 04, 2013, 11:24:23 AM
And that's what I believe that Igor will be up to, next, as soon as he get more supplies.
And hopefully Igor will also tell us how much input power is being used for the devices already demonstrated and show us details of his driver.
NickZ
    Hoppy:
   Igor has mentioned that he was using about 70 to 80 watts on his second to last video. He is still working to develop and optimize his newest Royer oscillator circuit, that has replaced the more expensive and complicated induction heater driver. As the cooker circuit could not be feed back from the inverter. Which is possibly the next set of tests, to try to get working in syncro. Royer running from the inverters output.
  The driver details are basically the same as is mentioned on the Internet for the Royer heater circuit, and look very simple to replicate, as well. Unlike some other devices we've seen up to now.  His intention is to share ALL.
screen
Hoppy
Quote from: NickZ on September 04, 2013, 02:58:26 PM
    Hoppy:
Simplicity is the hallmark of TK's devices by his own admission. We now know that it is more than likely that TK & probably Akula used a hidden external supply to power their various devices, so experimentation along the lines that IGOR is demonstrating seems like a logical direction to take: that is, consume power to produce more power.  :)
magpwr
Hi everyone,
It seems late last night i have made a technical error on the 1st layer winding base on my earlier posting.
It's suppose to be 25 turns blue "center tap connected" then continued by 25 turns brown(wire colour optional).There should not be both clockwise clockwise winding on 1st layer.
I only realized this mistake today upon completing one half of winding which did not tally with with brown output base on picture.
I have attached my current device at this moment without the primary winding.This is a tricky part as too less winding at primary will increase unwanted current draw and reduce efficiency.And too many turns for primary would make a "lousy driver" for the secondary coil(low voltage\current output).
Plan to complete device only by tomorrow.Through trial and error start with more windings then reduce little by little to find sweet spot. :D
The secondary winding is about 23 turns per layer.There is 3 layers for secondary.In the SR193 photos looks like around 17 turns per layer.
