0 Members and 426 Guests are viewing this topic.
color
r2fpl
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/msg559190/#msg559190
The size of the grenade coil doesn't matter.
How the transformer and the kacher work together is important.
r2fpl
Quote from: color on July 16, 2021, 08:44:55 AM
r2fpl
Of course the grenade doesn't mean anything. It's a normal coil and looks good with an inductor. There is no magic.
Probably Ruslan uses aluminum foil cut under the coil for capacity pickup. Today I did such a test and it works very well. The bulb burns with grounding.
color
r2fpl
According to my dad's magic, aluminum has no special meaning.
Looking for a heat-resistant metal without affecting the grenade coil resonance, aluminum was the only choice.
r2fpl
Quote from: color on July 16, 2021, 09:21:21 AM
r2fpl
not true, aluminum slows down the wave and catches the radiant.
Only resonance are not enough.
color
r2fpl
You are interested in the structures that support the grenade coils.
unnecessary.
Porcelain can be used instead of aluminum.
Please recommend a heat-resistant and non-resonant metal that you can replace aluminum with
Avoid expensive metals like gold and silver.
Да. Именно об этом я и говорю. Мы оперируем тем, чему научили, в чём выросли.Здесь-же надо найти то, чему никто, кроме Теслы, не ковырял. Его просто "задвинули".
https://realstrannik.com/forum/btg-tarielya-kapanadze/1389-btg-kapanadze-teoriya-i-praktika-2?start=6510#167803
The inductor coil is what the kacher accelerates to resonance.
The grenade coil is all about amplifying the voltage.
"задвинули".
So your aluminum magic makes no sense.
