0 Members and 45 Guests are viewing this topic.
r2fpl
color:
The rule is not clear because nobody has shown it.
Aluminum is similar to a cadeuse coil or a non-inductive coil.
AlienGrey
Quote from: r2fpl on July 16, 2021, 02:07:21 PM
color:
What makes you think that ? prove it by explaining the properties of each quote.
Regards Sil
AlienGrey
Any way lets look at Ruslans Tesla coil with the 37.5 meter wave length  my calculation works that out to be 2mhz
If we cut this down to 1/2 wave length 19 mtr then we have doubled the tuned frequency 4 mhz
across the tuned katcher or Tesla coil but circuits show a capacitor across the 3 turn coil of around 5 or so NF
in an effort to lover the frequency to 2mh, all this does is to cut the wave length into 1/4 section of the wave across the
Katcher coil's length and note if there is no crossing of the node the coil wont have aq phase shift and there for wont oscillate.
Also the way the grenade is built in 4 sections that wont work either not correctly !
Regards Sil
r2fpl
The coil granate does not have miraculous working properties. If it were so, the next Ruslan coils would always be the granate coil. This shows that it is something else or nothing. Maybe the inductor would fit nicely or give the impression of mystery. Yes, if you analyze the magnetic field around the coil, you have the impression that something miraculous is going to happen, but when you look at the oscilloscope you see a steady or jumping sine but the field is known because the coil was made this way. All ratios are frequency dependent and have a lot of tolerance as you know. Mere resonance does not add energy but multiplication. Unfortunately, not for free. If you understand the essence of resonance, you know that there is no resonance without driving force.
A question that everyone wants to know where to get this extra energy. From the environment because it is clear. The sun and the wind are also the surroundings.
So where does Kapanadze get his energy from? If you have had time to watch and analyze all Kapanadze's films and think about what is common to them, you will see that there is always a thick ground wire and there is always a current of approx. 24A for 5kW. Have you tried to make the ground wire show 24 A on one wire!? Do it. Check how to do it. This is essential if we want to replicate Kapanadze's device. It is always a steel pipe! this is another important tip. Even Ruslan or Akula connected to the iron pipe!
Forget about Kapanadze's brass cooler for a moment.
Why to water and to an iron pipe? that's where the energy is from. It is not only grounding, because if it were so, the grounding pin in the electrical socket would be enough.
Now answer the question what's in the iron pipes in the ground ?!
AlienGrey
The iron in the ground ? are you refering to the energy from the ground earth, Well the thing is how much have you built ?
how far have you got ? the resonant frequency of the univers is about 9 hz or a muliple of it.
http://docshare01.docshare.tips/files/4004/40045676.pdf
http://www.free-energy-info.tuks.nl/P26.pdf
Regards Sil
