0 Members and 529 Guests are viewing this topic.
r2fpl
Again: why Kapanadze, Akula and Ruslan use an iron water pipe?
See foto:
These are just selected fragments. Kapanadze even in older devices is always grounded.
Of course, you can say that for safety reasons, why such a thick cable? 4mm2 is enough and why is 24A on this wire!?
Instead of counting coils and calculating resonance frequencies from harmonics, let's answer this question.
Kapanadze does not have an oscilloscope and accurate frequency meters. You know it, but you are looking for a very specific frequency. I agree; maybe Kapanadze has found some frequency for which he is the energy supplier. Everything is possible.
Now what I know: a steel pipe with water or gas carries earth currents! These currents are from the heating of the earth by the sun, earth waves from motors, induction and storms. These are very low frequencies <10Hz and even <1Hz. This is similar to or the same as Schumann waves / resonance and this also generates Zenneck waves.
Wesley writes about it all the time.
Kapanadze knows how to pick up those waves. For this you need a voltage difference.
I did a lot of setups with the Ruslan, Akula device. with kacher, without kacher, with TDK, TDKS, Dally ns pulse generator.
I never got anything extra so I focus on what I wrote.
AlienGrey
Your on a wild goose chase, A CB is some times used in a car it to is made of steel but you don't
see a car attached to a pocket CB or 2mtr A Radio hand held do you? Some of the remote rural farms have an out side
water supply they to have a galvanised water pipe too.
Your wasting your time casing that idea.
Wfere are you ? do get Elektor mag azine some years ago 30 or 40 years ago it did an artical about a collecting
electricity from the air did you ever get to see that artial ?
For a start an electron isn't what you think it's a magneticly charged free radical, it's item pic was a hand held
device and a guy at a station collecting energy from over head power lines ;D ;D
Sil
r2fpl
I do not force anyone to think where the extra energy comes from.
If so many people replicated Ruslan and got nothing, then you probably need to look for additional information.
It is not a CB radio or any typical broadcast station. Anyway, these are only my assumptions, not the answer.
Maybe you'll come to my statements in a while or not.
In a way, the coil itself is already giving an FE. 2x A steel pipe in the ground also gives electricity, but not much.
The question is if maybe more. How are you supposed to get the energy from the 10Hz carrier wave !? show me such an antenna and resonant circuit.
So until you confirm you have it, you won't find out if this theory has any validity.
Maybe Kapanadze discovered a resonant circuit that works at xHz. The Corum brothers have a patent for a low frequency antenna.
Wesley pointed out this many times.
AlienGrey
Here is a grenade i have been experimenting with, originaly i just wound 20 mtrs on top of another 20mtrs
but it didn't perform as i wanted it as it wasn't symetrical physicly or it's wave form it produced.
Any with a bit of thought I got what i wantedat it's output.
this device worked at 3.684 mhz different winding lengths will tune to different 'F'
and i dare say adding 'C' will alter F too.
Winding 1 xxxxxxxx\ /yyyyyyyy winding 2
Winding 2 yyyyyyyy/ \xxxxxxxx winding 1
It's ouitput driven by a SGen
Regards Sil
color
Iron has a greater ionization tendency than copper.
TROS -- Don Smith III "tuning"
https://www.youtube.com/watch?v=fVj08I_A_KE
구리보다 철의 이온화 경향성이 크다.
3~5 %의 황산 구리(Ⅱ) 수용액 속에 표면을 잘 닦은 못을 넣으면 못의 표면이 불그스름해지면서 금속인 구리가 달라붙는 것을 볼 수 있다. 이것은 구리 이온(Cu2+) 상태로 녹아 있는 황산 구리(Ⅱ) 용액에 철(Fe)이 들어와 전자 2 개를 구리 이온에게 주고 철 이온(Fe2+)으로 산화했기 때문이다. 전자를 받은 구리 이온은 구리로 환원되면서 못에 달라붙게 된다.
    Cu2+    +    Fe    →    Cu    +    Fe2+
구리 이온         철           구리      철 이온
한편, 염화 철 수용액에 표면을 잘 닦은 구리 철사를 넣으면 아무런 변화도 볼 수 없다. 염화 철(FeCl2)은 수용액 속에서 철 이온(Fe2+)과 염화 이온(Cl-)으로 이온화한다. 그 속에 구리를 넣으면 구리는 철보다 이온화가 잘 안되므로 전자를 내어 놓지 않아 반응이 일어나지 않는다.
Cu    +    Fe2+    →    Cu    +    Fe2+
구리       철 이온        구리       철 이온
철이 공기중에서 쉽게 녹스는 것도 이온화 산화반응입니다.
Iron easily rusts in air through ionization oxidation.
