0 Members and 43 Guests are viewing this topic.
Dove
100% correct.
I've been watching these threads for years I maybe mistaken but for about 15 years and have always kept quiet, just observed, I know it shows me as a newbie, but that's not correct its because my mailing address and name has changed a few times because of work.
Delamorto showed that if you place the copper plate inside the coil and the ferrite inside the copper plate there was a huge difference in the output, that's why i am trying to get you guys to look at ferrite on the inside of the copper plate as a 50Hz resonator.
Correct me if i am wrong but what was it that CosmoLV said when Delamorto first showed this on his video, The guy almost had a hissy fit and said were getting to close to the real thing.
Do me a favour look up copper ferrite resonators, there are quite some surprises to be learned.
Another observation that i made with a tesla coil I built years ago, ill find the photos and post them for you guys, the coil was built in the normal fashion, except i did not do the conventional thing at the doughnut, there i placed a flat circular disc covered in copper foil, then i built two small coils on top of that connected to the flat plate, and a copper ball on top with a short delay line tube to the ball, well guess what the voltage and current phases lined up there was no lag or lead in the power factor.
Something else i realised years later was that at the flat plate the brush was not moving away from the plate but rather moving toward it almost as if the energy was being drawn in.
These are all things that can help I hope not trying to move you guys away from the topic at hand.
Best Regards
Chris
magpwr
Quote from: AlienGrey on February 15, 2022, 04:09:44 PM
Hi Magpwr, yes your right about the comparator add on section, What i'm testing for here is standing waves in the catcher coil winding Vasiuc41 describes in his PDF over on OUR tech publications,
Have you managed tried to achieve standing waves within your catcher circuit or is it BS, Some time ago Delomorto showed a video with a catcher wound on a pvc pipe with a split copper water pipe section in side the pvc pipe and used an old tuning capacitor for maximum spark thus lighting up a large 240 Volt bulb in series with the earth feed.
Sil
hi AlienGrey,
Regarding Tesla coil provided if you are comparing between various tesla coil design with respect to frequency.
You may by now noticed that Tesla coil of certain lower frequency produce "blue plama" and "higher frequency" eg:HFSSTC produce hot orange plasma even at a lower voltage source <20volts.
This is the one we should be interested in where even mains bulb can be made to glow easily at low voltage even merely by touching tip of bulb to the Tesla coil.
If you own a high frequency current probe or little cheaper alternative eg:mini RF AMP meter which is connected in series with bulb to Earth.
Then you will know at which Tesla coil frequency would produce a better result.You may already know the AM ferrite rod is good up to 10Mhz but more realistically  around 8Mhz or lower. used in Akula kapanadze demo,before the Antenna winding as example.
Lets see what your findings are base on experimental test. :D
AlienGrey
Quote from: Dove on February 16, 2022, 06:45:48 AM
100% correct.
Best Regards
Chris
Mr Dove, I know the Delamorto  device your talking about I knocked that device up in a couple of lunch breaks at work it lit up a 60 Watt light bulb but it wasn't FE.
It's a bit difficult to visualize your meaning in the plate and brush comments , have you a photo you could please post i'm sure some of us would be interested.
Regards Sil
AlienGrey
Quote from: magpwr on February 16, 2022, 08:50:32 AM
hi AlienGrey,
Hi Magpwr 8Mhz would be difficult to produce a self oscillating catcher coil and to get it going as so with 6 or 4 Mhz it wold possibly need 2 inverted driver stages before the NPN 2sc5200 for the feed back oscillation and the 0.6volt device voltage drop would produce a lot of heat as in that mode the bias needs setting to the mid point of the gain locust which draws loads of current before it starts and runs, where an on off rail to rail would work just as well but would be far less energy wast full.
It might be best to use a MOSFET a but that two would need some power full driving due to the charge discharge capacitance
how did you solve that problem ?
Regards Sil
NickZ
   Guys:
   First time I've seen that there is no Color's thread showing up.    Did he finally get the boot?
   Or, is that too good to be true?  I hope so, as I do miss seeing actual scope shots, and the testing involved.   Instead of just religion, and girly pics, talk, talk, and more unrelated talk, etc.  Huge yawn factor...
   PS.  I find that anything over 2 MHz for a Stalker device type Kacher frequency is going to be too weak.  If running it at any higher frequency than 2 MHz it just gets weaker and weaker.
   NickZ
