0 Members and 76 Guests are viewing this topic.
NickZ
  SL:
   I feel that a similar thing is happening in the Ruslan/Stalker devices. The "sweet spot" frequency is very very narrow, also. But, there also seams to be something else which makes that narrow resonant point move away from resonance, or to be unstable. At least that's what it looks like to me. I just get an additional bright flash, on the bulbs for a second, then it moves away from there, in the next instant. I don't know what to do about that. I have shown that effect on my last video that I have previously posted. And that is also where I'm stuck at, today.
   Vasik:  If you don't want to show what you have mentioned concerning your work on your improved tuning efforts lately, you can always post a PM to me, instead. Perhaps you can show a video, as well, when you are ready. The "air" seam much calmer here.
   What I am still waiting for, is a self runner. That is the only option that makes sense to me as proof, as there are many readings and measurement error in all the previous tests on these, as well as ALL other devices tested. Itsu has spent thousands of hours to verify that so far and up to now, self running, is no cigar. Even what may look like OU, due to readings, has not been enough to allow for self running, as yet.
   NickZ
SolarLab
 Hi NickZ,
Thanks for the "priceless observation" regarding your testing (an independant source from a learned,
experienced hands-on, experimenter). Appreciated here more than you know!
Could you please provide a link to the video showing this effect (your last video) so I'm sure we're on
the same page, so to speak. TIA.
Almost there - you can just "feel" it!  :)
SL
NickZ
   SL:   Below was my last video on the subject of tuning the grenade coil, and Kacher. As was recommended by T-000, and used by Ruslan.  This current transformer method works for me, but, there is still something needed to be able to sustain the "extra energy" pulses. Up to 3 200w bulbs have been used as load, also. Main idea is to obtain self running... nothing else will do.   https://youtu.be/9UxOvZatzKY   All my other videos, can be viewed at Nick Zec channel on YT.
   Glad that you "can feel it" I wish that more of us could. If we don't believe in something, we won't even see it when it comes.
It will be as if invisible to us. Good for the "what ifs" though.
   NickZ
SolarLab
 NickZ - I know you have been told to try a thousand things so I hesitate to suggest anything else -
But, just from your video - you probably have noticed that the "base circuit - everything without the Katcher - is oscillating;
appears to be a somewhat random very low frequency (likely involves a large capacitor and/or large inductor [you have both
in the circuit]). Almost a "fill and then dump" type thing.
Since the circuit is high Q (resonant), this is not uncommon; and the [positive] feedback causing the oscillation might be hard
to isolate. You don't need the HV on to troubleshoot this - take a capacitor .1uF, 1uF, 10uF, or so, and ground one side then probe through
the circuit [methodically] until you find the cause - and the circuit becomes stable.
Could even be the 60/50Hz in your lab - turn off everything not required (unplug Katcher PS).
Watch the scope top trace before induction circuit turn on - then at 02:52 through 03:00 (Katcher turn on).
The noise seen on the top trace appears to be "pulse bounce" but that's just a guess from the video. Play the video
from 02:50 to 03:00 at 25% and it's somewhat noticeable. {VLC player works good for this, also set two limits and loop}
The noise also takes a while to build in amplitude as seen in slow motion.
Thats my first pass WAG (Wild Ass Guess) anyway! This is an aside from the Stable Processor thats under development however.
Will look at it a bit more when I have more time... Hey, not much, but its free!  SL
NickZ
   SL: The blinking is caused by the looped feed back power supply. It won't do it if I disconnect it. That PS takes quite a bit of the output, causing that effect. When tuning is right, it won't do that.  Low frequency is not the problem. Induction circuit is tuned  to around 18khz, Kacher runs at around 1mhz.
