0 Members and 136 Guests are viewing this topic.
NickZ
Quote from: AlienGrey on September 05, 2022, 03:04:16 PM
Solar you don't need such a complicated micro as that a simpler micro PIC series cold handle the job if it wasn't for the EMP how you going to cure that problem, all those devices are charge coupled devices ? and a  Faraday cage then becomes a capacitor plate.
That's why the Ebons craft was brought down in 1947, oh yes it was a box kite or was it swamp gas from the desert  ;D
next problem.
So can you teach him how to program and as well ?
Sil
   Good point AG. There is about 5.000v to 10.000v of HV and HF running all through out my device. Micros would last about milli second.
   NickZ
    PS. Well SL, Really! Oh, in that case, then "I don't care", as well. As nothing seams to matters to you. How cool is that...
    Nor will your dissapointing negative posts and "extensive research", mean much to me, either. As you just want someone else to do what you should do, instead. And finally now express your real views, on all of this. Sorry to say...
quote:   "Either way it has nothing to do with me, nore will it ever have anything to do with anything, actually".
        end quote.
    Thanks SL, that was what I had thought you'd say.
    Have a good one, also.
ramset
Good we have some agreements !
Solarlab
In your sim file or ? On device mentioned here !
You must have some design parameters of components
Or coil specs etc etc ?
Perhaps some comparisons can be made to the builds ( itsu's?),
And your models ?
I know I would be most curious to see if units on bench can be modeled
In sim or versa visa
As a benchmark or starting point for a builder ( blueprint / spec it !
I personally like your path towards managing the system( s)
Especially since tuning and control of (____?)
Are apparently so fussy and repeatable performance
Is dependent on so many fussy bits !
Very cool indeed!
Sorry for musings
But I think we need a few of these !
Respectfully
Chet K
Ps
And do try to connect actual builders with this process ( systems micromanagement?)
Appreciate your tenacity ( for such a sensitive fellow( gotta be ruff !;)
Pps
Maybe some of your students could pair up
With open source builders and their bench devices?
Or ?
Just a discussion at this point ( feasibility ?)
Thanks Grandma
SolarLab
Quote from: ramset on September 05, 2022, 07:39:24 PM
Solarlab
And your models ?
Very cool indeed!
Sorry for musings
Respectfully
Chet K
Ps
Pps
Or ?
Itsu probably already has the initial Grenade, Inductor and TV Torroid files - I recall the hastle I had when
trying to post them. One problem was his SW was a version behind so his EMW sim wouldn't work.
Not sure if he ever upgraded SW. He also didn't have CST so playing with those sims didn't happen.
Those are still in an archive but its been a while so would have to search a bit - won't do much good however
unless you have the CAE with the same versions, and so on... The CAE's give all the component and system
specs, etc. Plus, you can extract individual component parameters for use in Spice (did it for Microcap12) which
makes it a bit easier on CPU time for optimization and analysis.
Have now moved to another CAE platform - more powerful but huge files, etc. Another story for another time.
The best thing to do IMHO is wait until the 10GB/s Webpage Host is completed and tested (soon,
apparently).
Trying to work the forum with detailed stuff, is, quite honestly not really doable. Web might have some interactive
CAE as well.
Everything will eventually be put up on that, with indexes, videos, searching, etc. and about 8TB of archive
info/data (goes back to '85 or so - even has Don Smith original stuff). Big project - bigger than I originally
thought - but it's moving along pretty fast.
Priority is to finish the "LinGen" with new Controller since it shows proven excess energy already, and it's simple.
Hey, I'm not you all's enemy - but I am the Boss, here in my Lab at least, and I do things in an order that makes
the most sense for me and the associates (a.k.a the Wheel Chair bunch, etc.)!
Regards,
maxolous
NickZ and Solarlab are the center of activities here.  Solarlab apparently seems to process what NickZ is  looking for but he his making things too complicated for NickZ. NickZ wants an improvement on his contraption just the way he has it on his mind. Now, Solarlab came with EMP32, what for? A very simple kacher , grenade and Tesla coil would be cool for NickZ.
By the way, who you to instruct.
Y
" You don't have a project"
" Your device does not self-run"
" Show me your work as I have showed mine"
" Nobody has been able to build a successful device"
" Even Stalker does not have a self-runner --------bla, bla, bla, bla"
Few pages had been added and nobody is working or had shown any evidence of working.
You don't pay the Piper, why should you dictate the tune.
The system is not plug and play, you must catch every moment. No two replications however how identical can work the same way.
There could be more than 10 variations that must be gotten right, without which there will be no effect.
I have been busy with so many other things.
I wish to resume before long.
Maxolous.
maxolous
Quote from: maxolous on September 06, 2022, 07:10:55 AM
Y
" Show me your work as I have shown mine"
You don't pay the Piper, why should you dictate the tone.
Maxolous.
