0 Members and 137 Guests are viewing this topic.
AlienGrey
I think if you go back and look at the wave form drawing on this thread it's not so much a an arking and sparking device
but more of an AM low altra sonic transmitter do you remember the old ultra sonic garage door controlers or the pond mist generater Hmm?.
Sil
maxolous
I found something ingenious in this topolgy. This was posted by" SL" . If you don't build a controlled TT, this is another way it would work. I recommend this to NickZ.
Do you notice the two frequencies, one 1.37mhz and the other 13.7khz? One riding on the other. One is your PP freq. while the other is your grenade freq expressed by your TT. I think this is inventive.
It is more like an AND gate, the MHz freq would only switch if and only if the khz freq signal is in on condition,  thereby the pulses of MHz signal will only express when Khz signal is in on state and taking that pattern of the half cycle of PP.
This is the disruption in action.
Maxolous
AlienGrey
On an Educational note!
That idea isn't new, (this tread again) I found that idea on a few circuits, but the logic diagram circuit is totally wrong, and H Moray
used 31.5 Khz  and (63.0(x2) that freq will divide by 6 or 9  two strange numbers to do with universe resonance and dare I say
it demonic dark stuff. Also note the above circuit long tailed pair if both circuit are-not in phase you will never get any output  :(
Stella the french guy was on here till Wesley started asking him too many questions  :o
any way Stella guy said unless the 'F' is a sub division of (423 the music note)  you get nothing if you add that number you get 9
it's in tune with the universe.
Also most of the logic circuits on here (this thread) need the  timing modules re designing or sorting out to get the correct wave forms.
Note Be aware i haven't built or successfully  modified any other circuits to prove or test !
Sil
ramset
So invite him back?
If Astra ( or ? Not sure that's handle) has another theory inline with
EDIT
So AG changed name to Stella ( not Astra )
Quite certain even Solarlabs students could model that into some sim ?
Or ?
Nothing ventured nothing gained !
And there will be no interruptions on a build discussion( split off to a separate discussion? So as to not
Tumble this one ?
Respectfully
Chet K
PS
These topics go topsy tervy all too often..
If your gonna go after frequencies or tones or ?
Best not mix it all up !:)
"Results matter"
And for builders ...so does being organized in a presentation or educational theory!
Also
a Simple benchmark statement to explain the path forward!?
Maybe Astra can write statement ( not sure you are writing handle "Astra"?properly)
EDIT
AG now says French person is Stella not astra ?
Remind me to quote you in the future AG
Yeesh !!
Thanks Grandma
kolbacict
