0 Members and 94 Guests are viewing this topic.
NickZ
   Here is an older video of mine where I am trying to show the interaction of the Kacher to the induction circuit, with 3 200w bulbs, as the load. Not easy to do, like if doing the same thing but using a 50w load. Sorry for the blurry video, using an older camera.
   Keep in mind that my Kacher by itself can light a 50w load of bulbs, and partially even a 100w load, just by itself. So, showing the interaction and sync at smaller loads can be misinterpreted as something that it's not. To really test this interaction at least a 300w load needs to be used, or you can be fooled by the additional wattage added by the Kacher, when it's job is to interrupt the grenade's signal, instead.  https://youtu.be/-UZ50Dvc6Lw
   This video below, is showing just what my kacher can do, just by itself, with no induction circuit. And improved rectifier circuit was built later, which provided by even higher HV output. Again sorry for the blurry videos. But, I think that you'll get the idea.
    https://youtu.be/mpS7noQZ7DQ
   NickZ
pix
Quote from: maxolous on September 08, 2022, 09:14:53 AM
If gradient coil works, why not. Is it not better to get it working first before improvision
Maxolous
Gradient coil is completely different and serves different purpose.
In Kapanadze- "grenade" coil is wrapped in a way to minimise self capacitance and get delay line of certain length folded. That's all.
AlienGrey
Quote from: maxolous on September 08, 2022, 09:21:46 AM
Sergey Stalker spoke on delaying PP signal to correct this. He however stated that an additional delay cct could be used to achieve this . He used NAND Gates b/w PP and Mosfet driver. He stressed that the signal while shifting them should both be at 180° to avoid problem in your PP I supposed.
Maxolous
Max with out gping through all of Stalkers info whats a PP ?
Nick in that video of yours the scope shot lookes like the Alexee device I dont think thats the right one for any thing to happen
he also showed another scope shot where it takes off.
PIX,
The other thing If the American Junta (petro chemical co) has a patent of all of them  it only lasts so long and they are probobly all stolen from other applicants. Using dedley force so be aware and wait for them to distroy the planit before you can go the zero point way.
Note I'm just repeating what Yank TV docs are repeatedly keep showing on TV .
Sil
