0 Members and 81 Guests are viewing this topic.
magpwr
Hi everyone,
At the moment related to SR193 and Don Smith experiment as demostrated in China.I merely purchased
1)12volts Neon sign transformer 7.5KV 20mA (Model DC-75)
2)20  x toroid ferrite core diameter 5cm (Permeability 2500)
3)Purchased 4 x 10KV 1Amp diode to be used as bridge rectifier    Exisiting 4x 40KV is not sufficient.
4)Purchased Microwave caps 1uf and 0.8uf as 1 batch.
5)Currently looking out for suitable MKP capacitors for Don Smith replication in the next few days.
6)Small Copper pipe(To self create induction coil) will be sourced locally.
Sadly this project will be resumed around 3rd or 4th Week of October.My home renovation starting at the end of this month.
DimaWari
@ 00
I believed it was incomplete circuit. No clear source of excess energy.
guruji
I'm still experimenting on Chubinidze coil. Regarding the resonance coil I think it's not a question of how many turns one should do but a question of inductance measurement.
00
Quote from: DimaWari on September 11, 2013, 11:43:17 AM
@ 00
the circuit is correct. and if you want to eat mangoes without worrying where the mango trees are then just follow the circuit.
nobody understands the free energy circuit which is self run and just need a kick start or jump start whatever you want to call that.
energy comes from resonance of 50 hz.
how to do it ? here is the recipe
make a 50 hz generator.
make another generator of 30-40 khz(flyback)
make a power supply of 12 volt 100 hz pulsating dc.(fwbr)
modulate power supply with 50 hz ac in series with 12 v ac before fwbr power supply lower than 220 volt ac and mix with 12 volt ac power supply in series as done by sr 193 hand drawn circuit. this pulsating 100 hz power supply is fed to 50 generator  and flyback driver.
result  you will have a carrier of 30-40 khz with modulation frequency of 100 hz. when this 100 hz  interacts with 50 hz frequency automatic resonance happens  in the coil setup and the output will be in phase (current and voltage) and the signal would be amplified sine wave.
akula did same but mixed tiger yoke instead of sr 193  spark and used 220 volt pulsed dc supply with 12 volt dc supply.
akula igbt
http://datasheet.octopart.com/FGH50N6S2-Fairchild-datasheet-27681.pdf
00
DimaWari
@00
Sorry if hurt your feelings but let me show you how I got into conclusion
that it was not probably SR circuit. Its how SR wind the coil, can you
see the difference? If it is just one coil you could wind it perfectly fit but
its not. Its a slightly mess of at the center of the core.
