0 Members and 126 Guests are viewing this topic.
stivep
Quote from: kolbacict on September 18, 2022, 03:59:36 AM
Do you see some analogy with the Holcomb machine, there is a virtual moving magnetic field, here is a "virtual electron beam". How do you like this idea?  :)
Holcomb doesn't use vacuum, the primary requirement for electron movement in CRT.
Your question is irrelevant.
The deflection system of a CRT TV  is one of the main consumers of energy, isn't it?
//how much energy is spent on shifting the beam, not counting the losses in the wires of the deflecting coils?
I suspect it depends on the speed of that beam.
Energy  spent on shifting the beam depends from the application but  is "close to none." in comparison to energy of the beam by itself.
In a vacuum chamber a tungsten cathode filament is heated to between 2500 and 3000 °C
to emit electrons, which are focused by a magnetic or static lens system
https://www.sciencedirect.com/topics/chemistry/electron-beam
Most smaller CRTs use electrostatic deflection,
https://nationalmaglab.org/education/magnet-academy/watch-play/interactive/electromagnetic-deflection-in-a-cathode-ray-tube-ii
The amount of vertical or horizontal deflection is directly proportional to the corresponding applied voltage.
In case of magnetic lens use:
-the amount of used energy for the deflection will be equal to the amount of energy used by your hand to move the magnet
used for that deflection.
Pushed by SolarLab experiments with Holcomb concept, so far looks like it depends on his mood,
-like a child or some young lady
He is learning, but not fast enough yet I assume.
"I do and then I don't, or I think I do, maybe"
"I give and then I don't, or I think I do, maybe"
"I talk and then I don't, "
"I move the subject elsewhere or move out, and then I come back."
"выехал из деревни, но деревня из тебя не выехала, "- sovok в нутри заклинил..
возвращать к жизни  вашy бензоколонкy вы можете, но, (Sovok V0.1.)  вероятно, не будете
note:opinion expressed is my own
Wesley
kolbacict
Quote from: stivep on September 18, 2022, 06:33:28 AM
Of course no vacuum. I just wanted to say that instead of something material, the rotation of a real magnetic rotor or the sliding of an electron beam over a phosphor, in both cases they are replaced   a virtual wave is making by switching elements .
QuoteEnergy  spent on shifting the beam depends from the application but  is "close to none." in comparison to energy of the beam by itself.
Didn't know this. Thank you. Definitely you have more knowledge. But appreciate the style of my thinking, damn it ...
I wonder if it is possible to make the sliding of an electron beam along the inner circle faster than the speed of light?
With a sufficient distance from the center of the circle.
NickZ
   Guys:   This talk about electron beams is very interesting, but, seam to have no relation to free energy devices, such as what this thread is about. This is NOT about sending electricity somewhere else, or comparing a Tv HV circuit to a free energy device.
Where is the free energy part??? Where is the proof that there is more out than in?
   It takes energy to "accelerate anything" how will this loss be covered, and converted to OU, or free energy, or a self running device? I see no proof of the acceleration of an "electron beam" as being responsible for anything that we are looking for, as yet. But, I am still looking for proof of that assumption.
   The idea that Kapanadze, and others have stated, is that the HV HF circuit (Kacher) or spark gap system, is use to temporally
stop the push pull signal, (such as when Tesla's generator switch was being turned off). And NOT to directly "accelerate" anything. But, to break (stop or quench) the push pull/yoke/grenade circuits magnetic pulse, at the right time and frequency, using the HV Kacher pulse, to achieve the needed signal, instead. Thereby, also pulsing the immediate surrounding medium (Aether), dark energy etc, to recover some "extra" or additional energy therefrom.
   So, please SHOW how conventional electron beams are responsible for the makings of a free energy device. Otherwise, I don't buy it.
   NickZ
stivep
Quote from: NickZ on September 18, 2022, 11:00:55 AM
   Guys:   This talk about electron beams //seam to have no relation to free energy devices, such as what this thread is about.
how ironic,-  in a way contrary to what is expected, and typically causing wry amusement
or funny because of being very different from what you would usually expect from researcher.
Rejecting general knowledge by illiterately blind, and by that not able to see, makes him limited, to see more if needed.
Our primate,Homo sapiens, born today while growing with iPods and computers would appreciate
at least use of modern toilet bowl I assume and definitely wouldn't reject the chance to learn more,
while entire modern humanity would make everything possible to enlighten him.
conclusion:
you never know what your idea can come from and what you can do
to yourself and others understanding 27 Slavic languages, talking  fluently 3 of them
some Hebrew, Idish and by that some German and English.
but you are not in this group!!!!!!!!!!!!!!!!!!!!!!!!!!!
you got me good!!!!!!!!!!!!!!!!!in sensitive place!!!!!!!!!!!!!!
I can translate the art of others you can't!!!!!!!!!!!!!!!!!
I can communicate while dosing knowledge in particular language  you can't!!!!!!!!!!!
you can't even have any slight idea what of that art relates to free energy and whatnot !!!!!!!!!!!
______________________________________________________________
Quote from: kolbacict on September 18, 2022, 10:26:55 AM
rotation of a real magnetic rotor or the sliding of an electron beam over a phosphor,  replaced   by a virtual wave //  switching elements .
speed of light limit is: 299,792 kilometres per second (186,282 miles per second) - fast enough to circle the entire Earth eight times every second.
These 4 Cosmic Phenomena Travel Faster Than The Speed of Light
https://www.sciencealert.com/4-cosmic-phenomena-that-travel-faster-than-the-speed-of-light-science
I'll write more just little later as I was trying, really trying to be as nice as possible
reading NickZ , comment... So I need some break now.
Wesley
NickZ
   Well, that is just wonderful Wesley, but, can you show us how to make a self running device?  No, you can't do that...
   I can also post and paste till the cows come home, as well. But, I don't buy the electron beam acceleration bit, as being anything needed, here. So, please show proof, other than how great you are. And how many languages you know.  As so far, you have not personally shown anything that works, for you, nor can you even light the smallest led bulb, for free. Sorry to say...   I am looking for scientific verification, not pipe dreams... Something you can't seam to provide.
    BTW: Wesley, can you save all your personal BS, for your own personal thread. As some of us are really here to learn about what this thread is about, and are not too impressed to hear about your toilet bowl ideas, or how great you are, all the time.
  NickZ
