0 Members and 86 Guests are viewing this topic.
NickZ
  SL:
   I tune the push pull yoke grenade circuit to it's best output, first. About 18KHz. Using 2000v WIMA capacitors to adjust for the best output frequency at the load of 600 watts worth of bulbs.
Then I tune the Kacher to it's best sync and effect at the output bulbs, using a current transformer first to obtain the highest current output readings from it.  Which works out to be about 1MHz for the tuned kacher frequency.   Then I say a few prayers, and....hope for the best. It can take a few days to actually see any effect generation though. And I'm good at tuning. Even in the dark, sometime is the best time, late at night. Not easy though.
   NickZ
SolarLab
I think my frequency ratio was 10:1 - oddball frequencies but the function generators didn't care (sub hz resolution).
Don't recall trying to use other ratios.  If you can, try dropping your PP to 10KHz or increase the Katcher to 1.8MHz - just
a shot in the dark, but you work best late at night   :)
You're so close - it's a piss off not to get it all the way there! Might not be long-term stable but that's for another day.
NickZ
  SL.  My push pull will only go down to 13KHz, or so. But I have not heard of any of these circuits running that low.  Using the 1/4 wave inductor 10 meters long, will lower the push pull frequency, lower than if using the 1/2 wave 19 meter inductor.   What only Itsu understands is,  that one frequency will affect the other one and will run it off the wanted set frequency sweet spot. Making it impossible to tune to your supposed best matched frequency sync, or what you might think is the best frequency match. You can tune one frequency, or the other, but not both. Check Itsu's videos about that.
  NickZ
SolarLab
Probably some ration combinations lower than 10:1 (not an absolute) that will work,
lets see  =>  GC and Ind coils are resonant at ? [not sure resonance is critical at this point]
=> X Katcher, has to be some even ratio higher, say (?) but the HV needs to exceed threshold.
I hate math!
The "Frequency Pulling" (interaction between, especially, oscillators is common, even at these low
frequencies and can often be due to the driving signals - one fix sometimes is to use 50-100 ohm
resistors on the lines driving the circuits. Sort of works like a "pad" of sorts, another trick is to
use a Pi or T filter thing. But that's beyond the scope for now.
The GC and Ind coils should not affect each other that much, even shorting them should be less than
a few uH difference - you can fool with this by short/open test on each. Stalker covered this in a video.
NickZ
  I don't hate math, but I'm better at tuning, even without a scope nor any test instruments. Same with Geofusion.  Both of us did our best with no test equipment. You have to become like the machine, in order to see some gain. Most guys will see no extra gain when the Kacher is also on. No  excelaration of anything at all, nor any higher output at the bulbs. The working bandwidth is minuscule. And this tuning all needs to be done with a minimum of 300w loads. Or you'll be fooled by an additional brightness on bulbs, at lower loads. But not at 300 to 1000w loads.
   NickZ
