0 Members and 110 Guests are viewing this topic.
SolarLab
Sounds like - well I don't know. Re-check and re-test.
Go through the device with a fine-toothed comb, piece by piece!
If it still doesn't perform as advertised - beat it to pieces!  ;D
If you have a scope, spectrum analyzer and percision generators that might help as well.
Did build my first tunable radio with nothing more than a sulpher-crystal & cat wisker, telephone
wire and a Quaker Oats Box tube however!
NickZ
  I do have those things, but ask Itsu if all his test gear helped. Or any one else.Believe me I have spent many long hours days and years, at this.Not for the faint of heart...   NickZ
SolarLab
Anyway, looks like my value added has expired - good luck with it and keep beating it till it obeys!
Look back through Stalkers stuff - his last video appears to be working, also Ruslan - his latest device
is interesting as well - uses a TV HV transformer instead of the TT. A few others as well.
Try the synced generators and drivers, at least it worked for me; but the stability is still questionable;
hopefully the fancy microController will help fix that.
Have a good one!
NickZ
 Every one's two cents are needed, if we can focus on this, instead of insulting each other. Good night, and thanks
  NickZ
maxolous
Quote from: maxolous on September 12, 2022, 03:14:59 PM
Standing wave do occur not only of waves of the same frequencies, it can also occur when one wave is an exact multiple of another. A very easy way to demonstrate this is to feed two signals into your scope from a dual channel signal generator. Let one be multiple of the other, without using the trig. menu, you will realize that both wave will stand especially when one is  exact multiple of the other or sub as the case might be.
Maxolous
@NickZ,
The best way to synchronize is to hang your probe above Antenna and feed to one channel of your Scope, while the other channel is reading signal from inductor caps terminals. Vary the frequency to match the multiple of Antenna signal, when they matches, both signals will appear to stand. It takes patient to do that.
It might not always be there , a little slip here and there. If one signal was running to the right tunee till it runs to left. Then, vary it to be stable and standing or dancing.
Haven done this, think of resonance. Use caps to get maximum voltage.
Maxolous
