0 Members and 94 Guests are viewing this topic.
itsu
Hi Nick,
if you look / listen to my video, you hear that around 20 second into the video i mention that the Kacher runs on 1.2MHz which is in sync / resonance with the Grenade base resonance frequency (according to its wire length)
So my 24Khz frequency on the push pull is 1/50 part of the 1.2MHz (50th subharmonic), so meaning i have a 1:50 relation between kacher frequency and Push Pull frequency if that is what you want to know.
But I have seen many different relationships coming by all these years, so your guess is as good as mine which one is the correct one.
itsu
NickZ
   Itsu:   Yes, I tried to explain that each self runner shown is running at different frequencies. This may imply that, what  is more important may be the match at coil frequencies, like the inductor is 1/2 the grenade output coil size, exactly.The Kacher may also need to interupt the push push pull signal, at just the right time.But what that right time is, is still not well known, in practice as yet. Since each device is running at different frequencies.
   NickZ
itsu
Well Nick,
there you touch upon another mystery, as a stretch of wire of a certain length will resonate at a specific base frequency, say 40 m will resonate at (speed of light in copper (m/s) / length (m)) is 270 / 40 = 6.75MHz.
Coiling that same 40 m wire up into a coil will change its inductance and capacitance, and therefor change this base frequency.
Especially the Grenade which is wound a certain way partly clockwise, partly counterclockwise will resonate at a different frequency as when it was a stretched length of wire.
So taking a piece of wire 1/2 of the 40 m wire and coiling that up in another way (bifilar) will yet change this coil resonance frequency in another way.
Expecting these 2 coils still being in some kind of special relationship because they have a 1:2 wire length relationship is very far-fetched if you ask me.
So i don't think these wire lengths used are any special, they just are there to have a base wire length to start building and fine tune using the series / parallel caps, but TUNING to what, that's the question (one of them).
Itsu
NickZ
   Well, just trying to figure out why the device is set up a certain way, which for now is beyond me.
And I'm not trying to re invent any thing. Just trying to understand what may be needed, or not needed. The fact that the inductor is 1/2 size of the output coil may be important.I agree that the way they are wound may also be important. Also was why I built the simple Kacher circuit. Without needing to place a HV pulse at any particular place.
  Good night, Itsu.   Thanks again.
   NickZ
AlienGrey
Hi all, thanks first to Chet and Nick for there patience and also to Itsu for his help in his reply. What has crossed my mind is this circuit others are using, where the katcher is modulated at which could possibly be .25 wave or perhaps divide by 40 of the 1.2Mhz main grenade frequency as disrupter so a 1.2Mhz freq modulated with divide by 4 test and a divide by 40 using a sine wave or 50/50 balanced sqr wave oscillator
So 1200,000.0 /40 = 30 khz
Sil
