0 Members and 307 Guests are viewing this topic.
AlienGrey
Quote from: maxolous on September 24, 2022, 11:30:47 AM
AG,
Please, emphasize on that , trying to picture it.
Do you mean the Inductor should be 1/4 from bottom too?
Maxolous
No that doesn't work the same way, lets assume the Tesla coil is in resonance to start with
get your scope probe and try it move it (a small difference a way from the coil as you do it)
you will find you just get maximum output 3/4 of the way up the tube.
The other strange thing is the way you wound the coil, When you empty a sink full of water
which way does it go down the plug hole clock wise or anti-clockwise ? depends on how you
wind your Tesla coil.
Sil
SolarLab
AG,
I get what your saying about the direction of wind on the tesla Coil but the
water direction going down the plug hole might not be the best analogy.
Depends on which Hemisphere (N or S) you're in!  :)
https://www.youtube.com/watch?v=QTTJJAiQFRc
Just sayin...
AlienGrey
So what if you live in Uganda and your smack dab where there is no rotating vortex
who you going to ask in the sticks ?
It's right hand rotation in the north and left in the south and the 6 ft in between
Move your device!  ;D ;D
So on your working device how did you lock your peak sine wave katcher output
for maximum ? or are you just using a Tesla coil ?
Sil
stivep
Quote from: itsu on September 23, 2022, 11:42:05 AM
As far as I recall, I never tried to "modulate the kacher".
What I tried was to synch the Kacher burst to be on the top (or bottom or anywhere in between) of the sine wave peak from the Inductor / Grenade signal.
This was doable, but did not show any special effects to happen.
What I also did try was to get both the Inductor and the Grenade resonance points to meet (to be on the same frequency) by adding / removing series (inductor) and parallel (grenade) capacitors.
It turns out that this is not possible as the resonance points seem to resist each other (like a band pass filter), so when tuning the Inductor to say 24KHz resonance, then tuning the Grenade also to this 24Khz resonance frequency, the Inductor will be OFF resonance and vice versa, see this video:  https://www.youtube.com/watch?v=ENOekS6zQos
It is unclear to me if it is NEEDED to have both Inductor and Grenade on the same resonance frequency, but it seems logical to me.
Itsu
In a series resonance LC circuit configuration, the two resonances X C and X L cancel each other out.
In actual, rather than ideal components, the flow of current is opposed, generally by the resistance of the windings of the coil.
Therefore, the current supplied to the circuit is max at resonance.
https://www.elprocus.com/series-and-parallel-lc-circuit-resonance
some other explanation is here:
The reactive branch currents are the same and opposite
when two resonances, XC and XL, are present. As a result, they
cancel
each other out, leaving the key line with the smallest amount of current.
In this state, the total current is at its lowest, while the total impedance is at its highest.
https://www.linquip.com/blog/what-is-lc-circuit
How in a parallel resonance circuit do the two branch currents cancel each other practically or diagrammatically?
https://www.quora.com/How-in-a-parallel-resonance-circuit-do-the-two-branch-currents-cancel-each-other-practically-or-diagrammatically
https://www.youtube.com/watch?v=gAbY2AevWv4
https://www.youtube.com/watch?v=vi24SpKYYoQ it is good to see it.
you may exercise yourself here:
https://www.sarthaks.com/3018902/the-current-flowing-in-two-branches-of-parallel-resonant-circuit-at-resonance-are
Additional link for these of you who are more  advanced  is here:
https://www.researchgate.net/figure/a-Existence-of-splitting-two-energy-levels-when-two-resonances-have-same-frequency-but_fig3_247777140
that explanation  includes phase and/or mode dependency factor.
Unfortunately I don't think it will  "talk" to SolarLab or NickZ .
In my opinion they are not there yet.
Wesley
maxolous
Quote from: AlienGrey on September 24, 2022, 04:41:11 PM
Sil
Yeah! AG, I think that's important too. Sergey Stalker referred to it in this video. Am sure he was particular about his location when he said he winds Electric field- counterclockwise and Magnetic field- clockwise as a rule.
https://youtu.be/v6FrGTF731o
Maxolous
