0 Members and 180 Guests are viewing this topic.
maxolous
Stalker's diagram never reflects loop current tap.
maxolous
Current circulating in loop is tapped after series inductor caps
maxolous
Quote from: NickZ on September 25, 2022, 01:00:08 PM
  Itsu: Green circle is how I have my tuning caps installed, but, they can get very hot and crack, even the 2000v wima caps. And are needed to tune the grenade output coil, before the full bridge rectifier.
Ruslan said something about not putting any caps before retification, but I will try putting before the retification. Let's see what happens.
NickZ , have you tried one reversed diode configuration. Experiment with that.
Maxolous
NickZ
  Max: You are looking at some older diagrams.
Newer circuits run on 24v and full bridge rectifier, before the feed back PS, and some more caps after that full bridge. There are many diagrams out there. None gave been replicated successfully by any of us, as yet.
   NickZ
AlienGrey
The problem with all the circuits your posting is the HF generating is on all the time
in the HV HF circuit of this type your displaying is it has no OFF time and this leads to Over heating
in the capacitors and the coils.
In Tesla's circuits he uses a charging of a capacitor at voltage peek and a spark gap to create an on off time
which also creates a higher voltage at re-switch on that's why a lot of circuits now use a lower
frequency oscillator to emulate the same conditions with a certain amount of control.
Sil
