0 Members and 181 Guests are viewing this topic.
maxolous
Quote from: NickZ on September 25, 2022, 07:00:55 PM
  Max: You are looking at some older diagrams.
Newer circuits run on 24v and full bridge rectifier, before the feed back PS, and some more caps after that full bridge. There are many diagrams out there. None gave been replicated successfully by any of us, as yet.
   NickZ
NickZ,
There is no old cct. Simply you now put a bridge doesn't not make it modern cct these were the cct Geofusion spoke about  in his later days when he was active here. Or you are looking at the date.
Maxolous
Quote from: AlienGrey on September 26, 2022, 03:10:42 AM
The problem with all the circuits your posting is the HF generating is on all the time
in the HV HF circuit of this type your displaying is it has no OFF time and this leads to Over heating
in the capacitors and the coils.
In Tesla's circuits he uses a charging of a capacitor at voltage peek and a spark gap to create an on off time
which also creates a higher voltage at re-switch on that's why a lot of circuits now use a lower
frequency oscillator to emulate the same conditions with a certain amount of control.
Sil
AG,
I guess you're right. There must be time off otherwise" Tesla will collect back what it gave" - Ruslan
Maxolous
NickZ
  Max:   There is more to it, than a just a full bridge, which is made with special HV HF ultra fast diodes, and it's on a 24v system, not a 12v one, using different tuning caps, and wiring routes, and many other changes. If you compare Ruslan's latest circuits with the older one, you'll see what I mean. He does show a 10uf tuning caps before the rectifier, and holds it in his hand.The main grenade output coil's tuning cap on Ruslan's hand drawn diagram is a 0.15uf wima capacitor, before the rectifier, also. Single or several of the non full bridge diodes get very hot, and burn out. And don't allow the whole current flow.       If you think that Ruslan said that about the simple kacher taking back what it gives, why does he along with Stalker and Adrian Gustav all three show videos of their simple Kacher circuits, self running? Are they all faking it???    I'm still waiting for you guys with the controlable kacher to show more than just barely lighting some small bulbs, with no OU, and no self running. l   Geo did talk about it, and did build the controlable kacher circuit also, which is NOT on that older diagram, yet he is showing no improvement, over the simple kacher. Dead time controls and all.   Ruslan's latest systems are not at all like the first ones.  Most everything is different, including no Tv yokes, a non kacher type circuit for the HV, etc... But, his original circuit schematics were never replicated and gotten working by any of us, and we spent lots of time at it, such as the TopRuslan7 system, with or without the simple or controlled kacher circuit, nor even using the spark gap idea.   Itsu replicated the Stalker version of the controlable Kacher, and Geo built two different versions of the Akula controlable kacher circuit. So we are still up in the air with all of this, as none of it has worked to self run the device, for us.   However, there is a new guy showing a spark gap type of device on YouTube, self running. I posted a link to it earlier.
   NickZ
SolarLab
NickZ,
Had to run by the lab yesturday and cover equipment, etc. (SOP). Try to avoid the place, but duty calls!
FWIW - Noticed the two Ruslan Generators on the bench - one had the 28(?) turns on the Yoke hooked to
the GC and the other one did not have the 28(?) yoke winding at all -just  like the Absolute schematic shows.
No time nor interest in looking at them further, but just thought I'd point this out. Anyway, what does this
28 turn yoke winding do and what does it add to the circuit - maybe a little power for the output bulbs when
nothing else works.
Just an observation, nothing more - a casual observation, a quick glance while passing by, that's it...
SL
NickZ
SL:  We don't know for sure why the yoke needs two secondary windings on it.There is one secondary (3 turn coil) going to the inductor coil. And the other 28t coil is going to the 37.5 meter grenade output coil. As that is how the Ruslan/Stalker schematic has it, we try to follow the schematic, and follow the intructions. There are several versions, so, take your pick.
   STALKER SHOWED A SINGLE 3 turn coil version as the only secondary coil on the yoke, also.
   Absolute has not shown a selfrunner, that I am aware of.
   NickZ
maxolous
Quote from: NickZ on September 27, 2022, 04:32:30 PM
   NickZ
NickZ,
The three turns is to run your wave, a kind of format for the system to work and not necessarily for lighting bulbs, the 28turns is for a little additional power. As you stressed some use it while others don't. It can also be a source of power supply to controllable Tesla or  simple Kacher when rectified and filter . This was demostrated by Geo in one of his videos.
Maxolous.
