kolbacict
You all make grenade cylinder form.
why wouldn't do it round form.
The ends of the cylinder are open and break the magnetic field.
May  will have occurred miracle in that case?
You don't have any imagination. ;)
AlienGrey
Quote from: kolbacict on September 29, 2022, 02:45:39 AM
Don't have any imagination Eh!
Ok then explain how the whole device works and what your device consists of and how IT works
and why you think it's any better than any other idea !
Then you might get a response.
Sil
kolbacict
QuoteOk then explain how the whole device works
To be honest, I don't even know how it would work. :-[
This "kacher" was made a long time ago, the primary winding has been removed here.
To see what will be the differences from the usual rod.
But apart from problems with the breakdown of high voltage at a close distance between the beginning and the end, there was nothing interesting. It just caught my eye...
Just "kacher" turned into a ring. :)
rakarskiy
The fundamentals of what the fields are aiming for must be known.
The magnetic field of this ring, just to such a state, the magnetic flux tends.
An electric field is a potential difference that, when closed into a ring, tends to self-destruction.
The principle of electric power industry is balancing the generated electric field through the field channel (conductor) by elements that slow down this process, releasing heat, light and, when twisting the conductor into a coil, a magnetic field in the form of a dipole. At the same time, Heat and Light are also magnetic fields, which can be attributed to the ray electromagnetic field.
That is why the secondary winding of the Tesla transformer has an elongated solenoid to create electric field potentials.
And a solenoid twisted into a ring is the creation of a magnetic flux, which can be created in the form of a plasma, for this a collider is being built.
The magnetic properties are lost by the magnetic circuit when heated, and not by the electromagnetic field.
More or less like this.
AlienGrey
If it's not too much trouble could you please explain your quakery in laymans english as i havent a clue what you trying to explain.
Sil
