0 Members and 114 Guests are viewing this topic.
stivep
Addressed to everyone:
Everything is simple. Understanding makes your life easier, better, good, or prospectus.
An "idiot", may become a scientist, and unlikely reverse.
If you are paid to learn then learning becomes your source of income,
but if you already learned something, then you can choose your source of income.
-if you are in deep sh*t it is likely your fault,
your laziness, caused by lack of motivation.
Guys in FE:( free energy)
I am sure that if I was to charge you, you would read every word
just because at now - most of you don't appreciate
"free" and given.
Advise:
if you are Russian, and not yet 40 years old leave Russia now to EU or USA or Australia.
before you become cannon meat send to die or loose parts of your body from hands of Ukrainian freedom fighters.
I am positive at 99% you will make more money there at any job .
e.g garbage remover – sanitation worker makes average $265,000 in USA New York.
Midwife, nurse, right after the school makes starting salary in average of $77,000
in USA New York.
_______________________________________________________
Quote from: AlienGrey on September 30, 2022, 11:27:15 PM
Wesley being a person of vast knowledge and scientific know how, Perhaps you could explain the mixing of frequency's in
tuned coil modulation known as synchronized standing waves of a full wave winding and a quarter wave ?
Regards Sil
some simple facts at first:
For electromagnetic  fields such as radio signals or visible light,
"free space" is any medium at which the waves travel as fast as they possibly can.
(this description is only partially true and maybe confusing
https://forums.anandtech.com/threads/freespace-vs-air-vs-vacuum.2079450/  )
The mechanism of energy transport through a medium involves the absorption and reemission of the wave energy by the atoms of the material.
When an electromagnetic wave impinges upon the atoms of a material, the energy of that wave is absorbed.
https://electro-magnetic.weebly.com/vacuums-and-mediums.html
medium of a wave is any substance that carries the wave, or through which the wave travels.
http://lscollege.ac.in/sites/default/files/e-content/Lecture-19%2C%20Propagation%20of%20Electromagnetic%20wave%20part2.pdf
Standing wave
also known as a stationary wave, is a wave that oscillates in time but whose peak amplitude profile does not move in space.
The peak amplitude of the wave oscillations at any point in space is constant with respect to time, and the oscillations at different points
throughout the wave are in phase.
https://www.youtube.com/watch?v=vqv0hy_4iKM
When two waves coming from opposite directions superimpose, then the resultant wave formed is called the standing wave.
Since two identical waves move in the opposite direction, there is no net flow of energy or momentum.
standing_wave_
Our Tesla coil has the beginning and the end that is terminated by the top capacitor.
(The big metal thing on the top of the coil)
Transmission line has the beginning and the end. So we may visualize full or partial reflection that is causing standing wave and the effect would be similar to both:
Visualizing RF Standing Waves on Transmission Lines
https://www.youtube.com/watch?v=M1PgCOTDjvI
Basic Tesla's Experiments (Part 7) -  Standing Wave, Node, Reflection https://www.youtube.com/watch?v=nkMndCsNRQU&t=2s
mechanical analogy of the mechanism of standing waves is explained here:
Standing Waves on a String, Fundamental Frequency, Harmonics, Overtones, Nodes, Antinodes, Physics
https://www.youtube.com/watch?v=-8nn8hb0H8o
please remember that we don't to deal with mechanical waves at all  !!!!!
straight piece of wire
laying on the wooden dry table and not connected - acts exactly the same as if it wasa coiled wire
It has capacitance and inductance and resistance.(resistance is mostly omitable in the resonant circuits)
and when it is in Near Field of some frequency (any frequency) it may interact if its length or thickens + capacitance, + inductance ,
matches that frequency or its harmonic . https://en.wikipedia.org/wiki/Near_and_far_field
But important is also polarization - position of that wire on the table( e.g vertical,horizontal)
-vertical polarization is used for ground-wave transmission, allowing the radio wave to travel a considerable distance along
the ground surface with minimum attenuation. Horizontally polarized antennas have their electric field parallel to the Earth's surface.
Horizontally polarized signals oscillate from left to right.
https://tech.africa/what-are-the-differences-between-horizontally-polarized-and-vertically-polarized-signals/
e.g vertical wire or coil that is in resonance will not see and not resonate in horizontal position!!!!!!!!!!!!!
Difference between a coiled wire as antenna vs a straight. role of ferrite:
https://www.quora.com/What-is-the-difference-between-straight-antennas-and-coiled-ones
https://www.quora.com/Could-a-single-wire-antenna-be-a-coil-or-should-it-be-straight
Coiling the wire reduces the physical length of the antenna.
This is a useful ploy when space is restricted, but there is a loss of efficiency. (Radiation goes down, heating losses go up.)
There is also loss of bandwidth, but that does not matter for single frequency operation.
Tesla coil:
Measuring the Resonant Frequency of your Secondary Coil  !!!!!!!!!!!!
in that video: Resonance and Tesla Coil Basics https://youtu.be/fT5_MmeSeDU?t=433
-one signal  50 Hz or 60 Hz is in the circuit.
-second signal is a spark from the spark gap the applies heavy discharge impulse to the secondary Tesla coil
and because both of the signals are in the same circuit the second signal is modulating the first one.
How to Measure the Resonant Frequency of your Secondary Coil
https://www.youtube.com/watch?v=DF6WdTM8s4U&t=8s
this video may be confusing anti-intuitive, because usually when looking at a maximum amplitude for the resonance.
And we need to remember that we have two resonances one is serious one is parallel.
The explanation is that the coil is connected only with one wire for that measurement.
This video is showing the typical measurement although it is still connected with one wire to the coil:
Finding the resonant frequency of a coil
https://www.youtube.com/watch?v=egDmVZ3FXP4
The two wire connection to the coil is mostly used for the primary Tesla coil:
Tuning Primary and Secondary for DRSSTC
https://www.youtube.com/watch?v=GLyW1zRZymk
How I Tune a Tesla Coil https://youtu.be/9XXRoj4jIMc?t=183
Tesla Coil LC resonance vs standing wave resonance. https://www.youtube.com/watch?v=uRqdNNbeAAk
Double Secondary Tesla Coil https://www.youtube.com/watch?v=gM__JC7eOQo
Modulation:
Audio modulation Tesla Coil https://www.youtube.com/watch?v=ZlpeHkUWDrs
I didn't finish to respond yet  :
I will add either another section or add more information into.. this post little later
I need some break as this is my Jewish holiday time and I have to respond
to the expectation of people around me.
Wesley
kolbacict
Quote from: stivep on October 02, 2022, 02:46:55 PM
Advise: [/b]if you are Russian, and not yet 40 years old leave Russia now to EU or USA or Australia.
Wesley
Thanks for the invitation.
p.s.
How I regret that I am not a Jew.
Honestly. jokes aside... :)
onepower
stivep
QuoteAdvise: if you are Russian, and not yet 40 years old leave Russia now to EU or USA or Australia.
It's not all bad news...
https://www.huffpost.com/entry/volodymyr-zelenskyy-elon-musk-ukraine-russia-war_n_633c08d6e4b03e8038c1ecc0
QuoteAndrij Melnyk, the Ukrainian ambassador to Germany, also had stark words for the billionaire's first Ukraine-Russia poll.
"Fuck off is my very diplomatic reply to you," Melnyk wrote on Twitter.
The problem with the fascist/far right crowd is there too dense to understand the difference between tolerance and weakness. You see most good people are tolerant but only up to a point and once that line is crossed all hell breaks loose.
In my opinion Russia will suffer the same fate as the U.S. in Vietnam, Afghanistan and Iraq. They lost there ass and there was no way they were ever going to win against a population which refuses to lose under any circumstances.
Thankfully most of the nonsense were seeing will be over soon...
"Things don't change because people change there minds. They change because they retire or die"... D. Crockford.
The writings on the wall, Trump and most of his followers will be in an old folks home or six feet under soon enough. Putin's and his lackeys are all 65+ as well and the younger generation wants nothing to do with there archaic bs. China is also due for a make over and all those in the geriatric ward are losing influence fast.
It's the classic story of our children humoring there outdated and archaic parents just as we did when we were there age. Only now were the parents, the old people who don't understand how the new economy and society works. What are the the older generation going to do, force there beliefs on there children?, we all know how that worked out with us don't we, it's a joke.
It's almost as if the older generation forgot who they were when they were younger. It's a classic case of bigotry isn't it?, we claim we would never do such things at there age but in fact we did and probably worse. It's a shit show any way we look at it, lol.
AC
AlienGrey
One power;
Good speech there, back in the late 60s, 70s Some character professed to be
a survivor of the the Rusky royal family and also another character Rasputin
and his antics were to the for in teachings one often wonders if Putin and Rasputin
are connected in some way but then you mentioned Vietnam perhaps LBJ fits in
there as well, but at the end you put LOL  is that short for 'Lucifer Our Lord'
(it aint mine that's for sure)?
AlienGrey
Wesley thanks for the well known info you produced but there does apear to be
various ways to obtain resonance that speeds up or should i say cyinthsises
zero point energy.
like the combining of 3 different frequency's that are municipals of the original.
and of course quarter wave.
It would be of considerable interest if you could explain this Phenomena !
I guess the real trick is knowing how to put such a device together.
Anyway you might be interested in this device
https://docs.yandex.ru/docs/view?url=ya-disk-public%3A%2F%2Fy9hkMQ4V4NSa8S%2FBMtoDilmYRxm4HRvLao0TuZiJVqQ%3D&name=Tariel%20Kapanadze%20-%20green%20box_%20patent.pdf
Sil
