0 Members and 349 Guests are viewing this topic.
Hoppy
Quote from: 00 on September 14, 2013, 03:59:24 PM
we make ferrite core  toroid with split to produce high frequency ac.
00
Thanks.
It would help a lot if I could see a photo of your overall system build, in particular the completed 240v/12V ferrite transformer and details of its windings. I assume you have not done a video of your working system.
guruji
Hi 00
I did primary coil about 5turn
Is this good or it should be definitely 3T?
Thanks
totoalas
Quote from: Hoppy on September 14, 2013, 05:54:05 AM
What would you suggest as an alternative to a flyback transformer?
This maybe off topic  but I have  used ignition coil  and as OO said just a little output to produce resonance
in my E core set up    at energy amplification thread
totoalas 8)
00
Quote from: guruji on September 15, 2013, 04:54:07 PM
Hi 00
Thanks
5 turn ok but it must be thick copper tubing and if you dont have copper tubing then you can use any power thick wire make two pieces and join them in parallel then wind coil. the best coil is either copper tubing or  thick jumbo speaker wire coiling for primary.
00
guruji
Quote from: 00 on September 16, 2013, 05:24:27 AM
00
I'm using a thick copper wire that is around monitors.
Last time I tried again with last wound resonator setup but still no output >:(
I should wind another and do 1inch gap as you've told all CCW yes?
Ferrite rings are better you told me once yes?
Thanks for help.
