0 Members and 162 Guests are viewing this topic.
magpwr
Quote from: ctbenergy on September 21, 2013, 04:57:43 AM
hi magpwr,
I know there is no error on your part.
measured with Agilent U1733C
1 layer bifilar coil with 10 turns, 1.5mm CW (.0338Ohm)
1 layer bifilar coil with 10 turns, 1.5mm CCW (.0338Ohm)
2 coils in "series" (.0180Ohm)  :)
hi ctbenergy,
Thanks for helping in validating this interesting discovery.
Time to re-write those formula in the books. :D :D :D
If you are keen recently i have conducted this experiment to validate base on youtube link found below which show us all how to achieve "resonance amplification" the key to ou devices in the most simple to understand video.
http://www.youtube.com/watch?v=D7QiI8p1gi4
As per video for the CW and CCW winding i used say 6 turns but ensure both winding have similar inductance value (shown in LCR meter).Then i merely use similar high voltage capacitors 500pf (50Kvolts but 1KV..3KV would do) soldered to CCW and CW winding.For the center coil i used 2.2nf 50KV(At least 10KV or 20KV rated).The hot side of hv is going to spark gap.
I am able to achieve resonance amplification similar or better than the one shown in video.The trick is center coil got to be close to coil on the right as seen in video to get real nice resonance amplification.
The left coil is connected to Oscilloscope similar to video.
(Experiment on resonance amplification start to end less than 1 hour including winding and soldering caps after planning in head)
Once my entire home renovation is completed 3rd week of Oct.I will resume with couple of experiment in one go.12volt 7.5KV 20mA (25...30KHZ)Neon sign transformer and capacitors is on  the way at the moment for this experiment mentioned below.
I can't use modern HV transformer with "diode" for SR193 device.
Base on the link shown below.Please note circuit diagram isn't accurate i have already taken down the connection base on photo&video.
http://user.qzone.qq.com/278885050/blog/1378191565#!app=2&via=QZ.HashRefresh&pos=1378191565
