0 Members and 158 Guests are viewing this topic.
Hoppy
Quote from: magpwr on September 23, 2013, 08:30:59 PM
hi everyone,
I have stumpled upon a very important document which is related to "1/4" or "1/2" wave" .This is based on a member name "Zilano" whom have succeeded in creating ou device in another forum.
But his post were all deleted-i don't know how that is possible.But this pdf was complied by someone whom was smart enough to gather all the information beforehand.
Interestingly, Zilano appears to specify a system working in reverse to 00. That is, Zilano's primary coil is 00's secondary and his secondary coil is 00's primary. He calls is a reverse Tesla coil and maintains that to do it the other way round (00's way) will not produce an OU result. It makes some sense as he explains that a step-down coil is required with thick wire for the low voltage, low turns secondary and high current and thin higher turns for the high voltage primary.
I like your philosophy of shrugging off experimental failure on the basis that some components can be re-used for other projects. I've created a virtual junk yard of components over the many years I've been experimenting and building this and that project.
Hoppy
Quote from: 00 on September 24, 2013, 02:49:24 AM
the effect!
ac is superimposed upon dc.
for overunity make dc  voltage pulse at higher frequency say 30  to 80 khz (single layer orthogonal coil) and superimpose( ac 50 hz that means modulate) then resonate modulated dc to interact with 50 hz ac with dual layer orthogonal coil terminating in output reverse phase to orthogonal coil as akula did you will get overunity surely.
00
Nothing surprising with the lamp flashing.  ::)
00
Quote from: NickZ on September 24, 2013, 03:09:54 AM
   00:  It flashed? That's it?   Amazing!
the lamp glows dull before connecting blue wire. when blue wire gets connected to negative of the electrolytic cap you get same effect as kapanadze and bulb glows very very bright. it glows blindingly bright not just a single flash. keep the wire connected and you will see kapanadze effect in the bulb. you can try yourself doing this yourself and it does not cost you a fortune to see how the effect is  in reality.
make sure you connect hot end of the 12 v ac to the first diode.
00
guruji
Hi 00
today I tried the toroids setup but again no output.
Ok to tell you the truth I lost count on turns and did not glue the toroids together but they were tight with the outer wire coil as you told.
Still trying
Anyway thanks for your help.
NickZ
  00:
  Why do you make suggestions for other people to do, instead of showing the results yourself?
  Have you been following in T-1000 footsteps, his way of operating???
  If you think that something works, then show it working, don't expect others to do it for you instead. Which up to now, no one has obtained any useable results from your expert advice.
  Is this another case of the blind leading the blind?
  As far as Zilano goes,  same thing...
  The proof is in the pudding....  which has not been replicated.
