0 Members and 132 Guests are viewing this topic.
guruji
Quote from: Kator01 on September 24, 2013, 07:17:17 PM
guruji,
in the comment section of your video you stated that you will post the schematic. However no schematic does exist there
http://www.youtube.com/watch?v=6qRcp1c_u88
Can you post the schematic of this experiment here for us to get an idea of how you combined your self-made Bottle-Cap in this circuit and how you built this cap ?
What is the element you placed inside the pvc-tube ?
Kator01
That's Don smith circuit you can find it everywhere even on this forum.
Same to Bottle cap I found it on youtube how to make one. It's very simple just fill a bottle with salt water and insert a piece of coil wire to it from the cap.
Wrap aluminium foil around and you have it.
That's pvc pipe wrapped by another coil.
That experiment was'nt OU but again one has to go in resonance as 00;Don Smith and others  said.
Regards.
Quote from: magpwr on September 24, 2013, 10:25:51 PM[/font]hi guruji,I'm really very impress since you say you are a musician and you might have unknowingly put many engineers eg:electronics,electrical to shame :D :D :D If they fail in even lighting a bulb then they would say it's a fake easily just to cover up the failure.I hope this doesn't happen to me. :D :D :D I did saw some of the videos in the youtube which reveal how to observe for double helix waveform in oscilloscope which will faintly appear.But the "tuning" needed to get this double helix waveform is very narrow\tight window.Need the patience of a watch maker.
[/font]
I don't want to put people down by my experiments for sure.
Wish well to all engineers;electricians and all but yes perseverance is a great key in everthing that we do in life.
Searching like anyone else to get an OU circuit.
Regards.
NickZ
  I must agree with Hoppy, also.
  Lets not waste more time with illusions that are not proven or replicable.
  The opposite wound primary coils are nothing new, or really make any difference, one way or the other.  If you think that they do. Then show it working that way, and show how it does not work when wound the other way. Please. This would be a very important point. Even though I doubt that the opposite wound coils make a difference, I'm ready to be SHOWN otherwise.
  GeoFusion:
  quote:
  "I will make Pics and Videos and post them so you guyz could see what I managed till now.
         end quote
    GF:
    Welcome aboard!  Videos, diagrams, and pics, would be much appreciated.
                     Thanks for offering, sounds great.
        NickZ
NickZ
     @ Magpwr:
     No one will call your device a fake just because it won't light a bulb.
Sounds like you are a bit confused. Fakes are called that mainly when no real proof of operation is given, or when it's not replicable to any degree.
    As no one here has anything that is actually a "free energy device", don't feel like you have to be the first. If this were easy, it would have be done by many people, a long time ago.
   We are here to experiment and tinker on Kapanadze/Chubinidze/Akula and similar type devices, and to help each other out. No one will condem your efforts, much less call them fakes.  That goes for any one, newby, or oldie.
totoalas
Quote from: 00 on September 24, 2013, 02:49:24 AM
the effect!
ac is superimposed upon dc.
for overunity make dc  voltage pulse at higher frequency say 30  to 80 khz (single layer orthogonal coil) and superimpose( ac 50 hz that means modulate) then resonate modulated dc to interact with 50 hz ac with dual layer orthogonal coil terminating in output reverse phase to orthogonal coil as akula did you will get overunity surely.
00
http://www.overunity.com/6763/energy-amplification/msg370891/#msg370891
I think this what happened in my test
When only power supply 220 v ac  Neutral is connected   and   positive or negative connected to SSG circuit  with leakage / stray  Neutral passing to the pwer dc supply
going to the ignition coil      one wire to led lamps leg   and the other   water tap   connection all the leds got brighter
totoalas
NickZ
  This can easily be tested, and is caused by stray AC capacitance, and induction that's running in your AC house wiring.  Running even on the floor, tables, and even up through ones body.  And most likely NOT from the above explanation, or diagram.
  To test this: Turn your electricity meter switch OFF,  and you will see how the device, and the led lights all go out. This is usually caused by a less than proper ground connection at your outside meters AC grounding rod. So, this is Not free energy, and usually won't have much amps to it, mostly fluffy voltage, that will light only LEDs.
  That's why a 12v battery and  inverter are important to use for these tests, instead of the house ground or neutral.
  Just turn your meter off, and see for yourself.
  If this is not the case, let us know.
