0 Members and 729 Guests are viewing this topic.
NickZ
   Guys:
  So long as there is a need for signal generators, we are still at the guessing stage.
  Years ago Tiger and the team, had developed a yoke device circuit that was supposed to be OU. 1kw output from 10w input, or so. But, neither he or any others have ever been able to replicate the same results, or even show them to prove the point, even with the use of those two signal generators. Makes me wonder...
Also, why did they give up on it, with such great revolutionary "save the world" results?   Radiation sickness,  or...   or what?
  Then after this fear of radiation exposure, Wesley is now armed to the gills to combat  this fierse enemy. Good thinking, but still no overunity to be shown.
  High voltage interference, influencing the singing Geiger counter readings, maybe?
  I've seen so many hundreds of diagrams, that until someone (else) proves that it works, I'll just  "wait and see".
  So, who will be the first, to try this last crazyalex diagram?  Crazyalex maybe?
   @ menofFather:  I don't see a "TAKC", do you mean that there are two flyback CRT transformers being represented by the G.   Has anyone built this yet?
MenofFather
Quote from: Grumage on September 28, 2013, 04:10:26 PM
Dear MenofFather.
I do see your point. My concern was with the HV overwhelming the transistors however I now see the 50 Hz Signal generator has a transformer output, so this might just be OK.
Cheers Grum.
PS How does this translate into English?? I see ferrite sausage permeability 2000 but that is as far as my very limited knowledge of Russian?? Goes.  :)
I think permability is not important. And better must be (I think) if you use not 12 volts and one ampere, but 5 volts and 2 amperes.
MenofFather
Quote from: NickZ on September 28, 2013, 04:38:45 PM
   Guys:
Here one flayback transformer.
Tiger not get from 10 wats 1 kilowats. He only help build one schematic, where people get from about 40 W input 200-2000 W output, but this divice is big and radiate very hight radio signals, TV not work in this radiation - that is not good side of this divice.
Here in first post http://realstrannik.ru/forum/19-svobodnaya-energiya/134493-tigra-xitryj-transformator.html in youtube is Tiger transformer, that have overunity, about 150-200 precents (I calculate if lamps is good) eficienty. I try replicate, but not exatly, some diferents make and not get overunity like Tiger, you can try replicate. Schematic is very simple. Is tape from monitor (I think tape must have good permability) winded around transformer. Primary winding have about 700-800 turns for his transformer, every secondary 70 turns. For smaller cores need more turns, for biger cores need lees turns and depends on permabilty core, how many turns need. But better use biger core than in Tiger divice, with same number of turns and same or biger wire ticknes. Primary is 0,2 mm diameter wire in Tiger divice-transformer. Secondarys is 0,8 mm diameter wire. One lamp is 220 volts 40 wats and conetcted in iteruped socket of 220 volts, second lamp is 40 W 12 volts, on it voltage 13 volts, it conected to one secondary, other secondary is shorted.
Here is schematic. I it draw for one russian men, so discription's is in russian...
00
First filter. first frequency adjustor.
Second filter. second frequency adjustor
kapanadze
not many people understand  these words but those who do have Kwatts and Mwatts.
soon everyone will!
goodluck and goodbye!
00
