0 Members and 126 Guests are viewing this topic.
MenofFather
Quote from: From other Planet on September 30, 2013, 01:05:04 PM
It seems to be definitely akula video, as its filmed in same room. Watch the walls, the table and other stuff in room. What makes me really wonder, is , over on energetic Forum a completly different schematic is promoted by 00, this one: http://i38.servimg.com/u/f38/15/04/69/67/65nw10.jpg
So this i find a little strange. Whats the real schematic, any of those 2? Is the device working at all? Why after his first obviously working device akula changes to one that has this monster spark, which radiates lots of HF and probably also at some point will stop working through erosion of the spark gap and the relay (if the one over here is the correct schematic)?
Some answers?
Акула тут не при чём, да, это его видео, а фотографии уже другого человека. А этого другого человека ещё пока до конца не выяснили или есть там сверхединичность или нет, самозапитки то нет. Поэтому, наверное, поспешили выкладывать его схемы и фотографии.
From other Planet
Quote from: MenofFather on September 30, 2013, 02:38:32 PM
sorry buddy i dont understand russian, and google translate doesnt work very well for this. Can u maybe say in english?
ctbenergy
Quote from: Nightmare_T34 on September 30, 2013, 08:00:29 AM
More detailed schematic with his answers added from the forum thread.
hi Nightmare_T34,
thanks for the detailed schematics.
can you translate the text in the schematics, or post the text in russian?
Hoppy
Quote from: NickZ on September 30, 2013, 02:20:15 PM
  Hoppy:  If it don't hum, it ain't for real.  The humming is proof of a high amp output.
Right? As high voltage does not make that transformer hum, nor create heat. At least not as much.
Power dissipation results in the production of heat (V*I). Current is needed to light TK's lamps and lots of it! Keep asking yourself why his 'ground' wire is heavy duty for his 'green and transparent box' devices which feature large lamp arrays. Two possibilities: either the thick 'ground' wire is sucking -up loads of 'free' current from the ground, or else the current is being sourced from elsewhere and is being carried by this wire(s). Which do you think is most likely? The humming is most likely as a result of transformer overload.
MenofFather
Quote from: From other Planet on September 30, 2013, 02:58:19 PM
Video is akula. Big shematic abd photos is not akula's, white schematic with selfrunnig also not akula schematic.
