0 Members and 1999 Guests are viewing this topic.
GeoFusion
I have no fear at all guyz
I will try my best to show the measurements, might also bring up schematics.
I have to set this particular one up again, If I have to put measurements along with it.  Sure why not.
but I have another ones that  are far more then this.
So lets see how it will go
8)
Newton007
Quote from: GeoFusion on October 12, 2013, 06:55:07 PM
8)
That's the spirit! ;D
Hoppy
Quote from: GeoFusion on October 12, 2013, 05:30:28 PM
Hi  there Hoppy, (=
What you saw was something similar to what Akula's circuit.
Using a Ferrite Yoke from TV as you can see and 3 coils. 2 are used, one for circuit and other one for output load.
Can produces up too 2KW energy 120Vac~140Vac on incandescent bulbs around ~20Khz , Drivin by a simple Royer / heater circuit on 12VDC, consuming around 1Amp or 2Amps from battery.
Something exciting happens when  load is connected,
Everytime load is connected (incandescents) , amp draw descreases in input and increases by output, the more load you connect the more it decreases at input and increases in output.
As an example, it draws 1 amp from the battery and makes 3-5 amps from core at load output 127V+ AC.
But, toriod choke will get warm over time and the circuit.  Depends on how much load you have on.
But The core will sing When reaching 1Kw load connected.
managed to rectify the energy and charge back too.
Not here for my own greed, here for info exchange and helping others to go forward together (=
I will post one few more soon.
Cheers~
Hi GeoFusion,
Thanks for explaining your setup. I noticed that as you plugged-in the second bulb the brightness of the first bulb dimmed and when the third bulb was added, the other two dimmed. This is exactly how my setup functions because the output from the coil is very dependent upon loading. I'm sure that this is the case with both the Kapanadze and Akula setups.  My setup will max out with a very bright 60W bulb because my secondary winding is only thin ECW. As I add more bulbs the supply current drops but so does the pk-pk voltage across the load. I look forward to hearing more from you. If you could connect a scope across the output winding and show the pk-pk voltage as you plug-in lamps, this would be helpful to me and others who are experimenting.
NickZ
  Hoppy:
  Could it be that the shared bulb brightness drops due to added resistance caused by your thin secondary wires, instead. Although, That does also seam to effect Igors Royer circuit, as more load bulbs are added the first bulb dims. As well as Akulas devices.
  Please upload a picture of two so we can actually see what you are working with.
   NO X wires... Please...
                                    kidding
Hoppy
Quote from: NickZ on October 13, 2013, 11:47:09 AM
  Hoppy:
                                    kidding
Nick,
The resistance of the secondary winding does of course limit the amount of current available to the load but over and above that there is 'bell curve' type response when ferrite core is used for tuning. Each lamp loading will need to be tuned differently to achieve maximum power transfer, so what is best for a 100W loading will not be the best for a 60W loading.
