0 Members and 355 Guests are viewing this topic.
GeoFusion
Nick: yes, very soon, upcoming days vids will be available.
Awesome. I see you also tried and managed your version of using the Tv core and Aire core Coils (=.
looking forward to your progress and could help eachother on the way with Ideas.
Quote from: T-1000 on October 13, 2013, 03:26:14 PM
One thing is noticable there - the halogen is on blueish color which may be indicating cold current going on high frequency there. Are you running it on BEMF spikes?
Also is that traditional flip-flop circuit or is it like the end of the signal starts the second and only after the first is switched off?
Yes T-1000,  it's Cold (electricity) Current high frequency @ 20~ 24Khz.
I can hold on to both of the leads of output with my bare hands and bare foot and no shocks at all. even If I connect a bulb and go touching the leads, not even a single shock   :P
well, don't know if it's traditional or not but Chubinidze used this circuit.
I will post a rough sketch for you to see and others (=.
Cheers~
GeoFusion
 :) Windings on the core must be same direction and needs to be coiled all the way passing the gaps to the otherside of the core.
For the Two Gaps on ferrite, put 1 layer paper or tape between them for it to work and resonate.
Grumage
Quote from: GeoFusion on October 13, 2013, 04:02:02 PM
Dear GeoFusion.
Are you saying that the primary windings are wound in the same direction from the centre tap? Or that the primary and secondary are wound in the same direction?
Also if you have an LCR meter what is the inductance of your primary winding and how many turns did you have?
Thank you in anticipation.  :) :) :)
Cheers Grum.
GeoFusion
Quote from: Grumage on October 13, 2013, 04:31:00 PM
Dear GeoFusion.
Cheers Grum.
Hi Grum :)
Yes the Primary Coil with center tap is wound the same direction,from left to right , CW to CCW one coil.
and Secondary Coil is also wound the same direction as the primary.
Primary has 27 winds of 2.5mm² Insulated wire  and secondary has around 35 winds of 1.5mm² insulated wire
Well I do not have a LCR meter, I wish (=, but I will manage somehow soon.
Cheerz~
forest
so you have 2 .... gaps ....  ::)  or ????? something else ??/ think !
