0 Members and 120 Guests are viewing this topic.
Newton007
Quote from: GeoFusion on October 15, 2013, 01:49:37 AM
Hi Nick :) ,
Alright, I will post a pic below for  you to see the circuit I used in recent vid. ( this pic has no center tap and uses two toroids instead of one )
25 turns on primary 2.5mm  Wire gauge , 35 turns on secondary 1.5mm Wire gauge,  all Solid wire.
cap value, 0.33uf as I've said on the vid.
Srry about the unstable recording was in a hurry haha. Yes next time with more light near the experiment although there was.. oh well more visebillity next time.
Yes, I tried to feed back with an newer version of it and yes it charges the battery back, but cannot remove the battery though, no just yet, needs some more experimenting.
the form of use of a Roundcore project like that managed to stay cool for 1 hour. but after that it's hot needs a fan on it constantly and toroid. Did not test it yet in long term sins I terminated the session. Continued to the newer one.
last measurement I saw it pulling was 2 amps from battery when connecting 300 watt, on 500 watts it was rating 1.6amps draw from battery , it can pull max 3 amps on 12 volts but that happens without loading.
Yes the ringing is new by this circuit and Toriod, but when I change toriod gauge wire it will change the Singing too. to almost silent. Difference is that I'm using another type of Heater circuit here and toriod that makes the humming and singing.
Well glad to be at assistance and really hoping you guyz could use this for next try outs but this is only the fragment of what I have build (= hehe
Cheerz~
Hi GeoFusion
This has been helpful to my better understanding of your work. I hope to hear more as I am always learning something new. :D
Cheeers  :)
a.king21
Geofusion:
The most important statement you have made so far is that you were able to charge the primary battery whilst lighting your bulbs.
Could you do a video showing that and we will do the rest and collectively develop this product.
Obviously a volt meter on your battery would be essential.
Well done.
If it works, I have a circuit which would remove the battery.
You are a star.
NickZ
  GeoFusion:
   Thank you for answering all my questions.
   The most important point is the self running ability. The draw is not as important as long as the battery is still able to maintain a balanced charge while running the load. Removing the battery once started is secondary. As well as using an earth ground, or not. Have you tried it yet with an outside earth ground? Akula mentioned that his system runs cooler with it, as well as with the battery connected. As it appears to balance the operation of the device.
  Andreij also needs a ground for his set up, but not the battery, once started.
  If you find a smaller 12v battery like 4 to 7 aH, it can be easier to determine if it will maintain the balance of charging, to discharge rate. In anycase we will test that rate as well, when we make our replications.
  I am so glad that you are able to confirm my worries of this being an actual self runner.
  As nothing has worked for us up to now.
   Alright guys, start looking for yokes. Tv repair shops may still have some around.
ARMCORTEX
People of america, plz, start saving the site and wich seems important.
Nobody knows  what will happen when the goverment collapses and there is angry people everywhere.
forest
Quote from: ARMCORTEX on October 15, 2013, 10:23:31 AM
Explain...
