0 Members and 126 Guests are viewing this topic.
NickZ
   GeoFusion and All:
   When uploading pictures or diagrams here, it is best to re-size the original pics to 1500 or less pixels wide. Your Royer diagram is fine, but the pictures are not, and the Admins will get upset, as it can affect the site, if larger than their maximum sized attachments are made.
  I have also had all my multi meters mA readings scale fried, when testing high voltage Exciter circuits, etz...  Does anyone know how to fix that problem?  I already replace one burnt resistor that I found inside the meter, but it's still not working.
T-1000
Quote from: ARMCORTEX on October 15, 2013, 10:23:31 AM
People of america, plz, start saving the site and wich seems important.
Nobody knows  what will happen when the goverment collapses and there is angry people everywhere.
I was following events there, here is latest update - http://www.thestar.com/news/world/2013/10/14/us_senate_leaders_remain_at_impasse_as_default_deadline_approaches_shutdown_enters_day_14.html
Obviously it is wrong thread for stuff like that but anyway, it will shut down some conspiracy theories going around the 'net... ;)
NickZ
  Thanks T-1000:
   Did anyone actually think that anything other than printing more paper to cover debts was going to happen?  Just how that will be paid back apparently is of no concern, as it costs, almost nothing to print.
          What a government scammmmmmm!
   Good time to borrow lots of money to buy free energy devices, (if available) while you can, as soon you'll be using money for toilet paper.
  How to run your car on funny money???  By,  I_see_clearly.
Hoppy
Quote from: a.king21 on October 15, 2013, 08:47:02 AM
Geofusion:
The most important statement you have made so far is that you were able to charge the primary battery whilst lighting your bulbs.
Could you do a video showing that and we will do the rest and collectively develop this product.
Obviously a volt meter on your battery would be essential.
Well done.
If it works, I have a circuit which would remove the battery.
You are a star.
Yes, I look forward to seeing the battery charge whilst running a load. :) As Nick says its the self-running that's important and if the battery can maintain the load indefinitely then it need not be disconnected. However, be aware of 'fluffy' charging where HV affects the measuring instrument and gives a false impression of charging. I would like to see voltage measured by scope (not a clamp meter which is unsuitable for this application) across a very low value shunt resistor which will show (by application of Ohms Law) both the supply current and whether the load current is being maintained by the battery receiving a charge whilst on load. Bedini tells us that a battery cannot receive a proper charge at the same time as being discharged. This sounds like common sense to me, so I am hoping that GeoFusion will be showing us a method of switched charging.
GeoFusion
Hi Guyz :),
Thnk you for the support but as always I will support you guyz too with info and anything els.
@ a. king :
Yes about charging back is a big step for me here too, still not so satisfide how it works but it works somehow still, I will be somehow demonstrated in the next vid I will post (=. will try my best. Sins I'm limited on Tech for measurements but will manage soon on what i can,  the current System we live in makes things sometimes hard.. get's on my nerves sometimes.
@ Nick:
yes, that is true. that it's still possible to charge in that way still with battery connected to it, guesing the Duty cycle of the battery is needed for it to keep the circuit alive but I had in mind of a strong above 1000 Farad  DC Caps in it's place, ultra caps and that would Eliminate the battery.
I did manage to try out grounding points with the bifilar, one connected with a pin in earth and one on copper tubing of water supply. and it manages to light up 60W light but nothing more. But I know what you mean by grounding, just like a SG tesla coil needs one, for it to be at max potential.. but I think I need some help in that Area.
willing for you guyz to try it out too, so to figure out more of it, need to work together. Not here for fame, not at all.
I will try to post the pics in those dimension then.
Yeah the amp clamp meter got fried when I was trying to see what a SG from a Flyback was drawing from battery but the pulses where to much for the protection inside the meter and blew it. will get a new one upcoming week.
@ Hoppy :
Well the charge back does a great job to be honest  but as I increased power for the resonance in between ferrite and coilings. It became hard for me then to charge back had to find other ways to stepdown the energy and rectify, and have minor problems of overheating toroids, but managed solutions by experimenting on my own.
Charging back method is not directly connected to the same output wires I use to light, it comes from a bifilar that is separate  coiling  within the same HF energy Field (=.
http://www.youtube.com/watch?v=4hgA9j-4dB0&feature=youtu.be
Well i have something to say about Government and System, they are scum to the max having everything for them selfs and mind controlling the masses and hiding alot from public, well time is up.
We work together as one against this corrupt system we live in.
time to bring about good in between ppl and not to be like Sheep obeying corporate scum Cabal Illuminati.
I know one thing that is coming, is that they will try to stage something fake soon, a event that will shock many, involved with the Inbound comet and Ships.
But there is help on the way..
Cheerz ~ :)
