0 Members and 126 Guests are viewing this topic.
flathunter
Quote from: woopy on October 15, 2013, 06:42:15 PM
Hi all
here my replication
I was awaiting a good occasion to finally build  the flyback Mazilly ROYER oscillator , and this experiment push me to finally complete it
it seems to work correctly, on   12 volts and more , i can light incandescent bulbs  (not fully lit  ) with a ratio of each  flip- flop as per Geofusion indication
The tuning capacitor seems to be  very important  and i have to test much more  different settings.
Far from being OU at my level, i have to test much more
My yoke is a standard old TV
So guys at work
Laurent
Hi Woopy!
By complete coincidence I have just made a Mazilli ZVS circuit, very similar to your own.  I am using it to power my old Tesla Coil at the moment, and I was hoping to build a vacuum chamber and try some Birkeland 'Terella' experiments. I find it a frighteningly powerful circuit. But great fun!!! Here is a video of the ZVS, and the Tesla Coil I am powering with 2 12V batteries and the Mazilli
https://www.youtube.com/watch?v=6N1YGSUzMYU
https://www.youtube.com/watch?v=ztsv5iS96Rw
What is the connection between the (Mazilli / Royer) ZVS and this new Russian claim of OU? Am I missing something?
Thanks guys and good luck in your experiments!
Flathunter
GeoFusion
Hi guyz :),
@ Hoppy:
I will see how i manage to scope all of my experiments, sins I don't have the measurement equipments yet but very soon.
I do have a volt meter with also a frequency meter inside and soon upcoming days amp meter for use.
true that, that should be the best or only way to actualy determine the outputs and PK- PK Rms and other values.
Will manage (=.
@MenofFather:
Awesome improvement on the schematic :), This will help alot. I Also have one Royer Circuit that will run from 10Vdc -120Vdc. these should help for massive loading.
By the way, nice try with the replication, looking forward for further developement :), I see you used one "U" shape  core there?
try to connect the other half too, it will make a difference somehow.
I used IRFZ34N mosfets for my circuit at first then changed the mosfets to IRFP250N.
Cheerz~
MenofFather
Quote from: GeoFusion on October 16, 2013, 10:43:25 AM
Yes, one. I tryed two, but big different I not see, only frenquency lower with two. But is winded dificult, so not easy make in this setup with two. I in other setupts tryed two.
Hoppy
Quote from: Khwartz on October 16, 2013, 05:08:19 AM
Very nice you advise such rigour in the measurements, dear Hoppy.
In the same veine, I remember that to use light bulbs without comparition bulbs for the lighting means near nothing or is very unaccurate.
Indeed, one can give 500 W, because only 120 V of voltage harvested, to ten 100 W-240 V bulbs and light them.
Need to have always aside of the light bulbs load at least one same light bulb under its full normal voltage, so the brightness of each could be compared.
Could look insignificant, but quite important when it is about to check a possible overunity of only few points...
Amicalement.
Very good tip Khwartz about having a light bulb running on normal grid voltage next to the bulb being powered by the device under test. Its much easier to make a comparison of light levels this way. Another worthwhile exercise is to run a bulb from a grid fed variac on a power meter and note light levels v power levels. This is an eye opener which will show how easy it is to overestimate the power being dissipated by the bulb. Of course the most accurate measurement is achieved using a light meter measuring bulbs in a suitable enclosure.
Good measurements will show that setups of the build posted on this thread will typically run at roughly between 50% and 70% efficiency. The critical factors are getting the turns ratio, wire gauge and the air gap between primary and secondary optimised to load when using tubular coil formers. The 64K$ question is whether its possible to loop back this type of system running at under unity electrical efficiency, so as to self-run. I have seen no hard evidence that this has been achieved by anyone to date but I live in hope that the NMR experimentation being conducted by Wesley and his team and a few others will bring success.
a.king21
Geofusion:  I would be happy with a voltmeter on your primary battery with a loop back charging the primary from your yoke, whilst lighting a bulb or two.
If the voltmeter stays the same or rises then we are in business.
It will do for starters. Anyway I've ordered 4 mosfets and already have yokes, so will be replicating anyway.
The nay sayers can do what they want. The cat is out of the bag.
This circuit reminds me of lasersabers' which lit light bulbs very efficiently.
(I also got it to charge another battery whilst lighting a second bulb. But I'm not claiming anything... he he.)
My term for this is..
wait for it...
Superconductivity at room temperature.
There - I said it first.
