0 Members and 307 Guests are viewing this topic.
fantom
Quote from: d3x0r on October 07, 2012, 09:04:48 AM
and yet you have all the elements of the schematics....
1) 12 V
2) 12V -> 150+ x2
2a) 150 goes to power pulse for L3
2b) 150 pulses L1 coil which resonates L2
3) a pulse generator to pulse the 150 into L3
4) a pickup L4 to generate load/self power.
the 120V-12V is unnessecary if not looping.... and a lot of caps are superfluous in the 5V logic section...
In my BD I have only one 12 to 170V DC-DC converter. It's represent second secondary coil in original T1 to supply 170V to NPG.
In research mode I prefer to have maximum flexibility and I use separate module to generate 170V not connected to main GEN1.
Thanks
fantom
Quote from: verpies on October 07, 2012, 10:40:37 AM
According to the attached schematic (which is identical to your but translated to english), the transistor Q3 will invert the output of the NAND Gates in Integrated Circuit U3.
The polarity of the low duty-cycle pulse appearing on the output of U3 is determined by the switch S2.
Also, because Q5 is a N-Channel MOSFET then a positive voltage on its gate will make it conduct between Source and Drain.
If Q5 remains conducting too long then a destructive current will flow through L5, T1 primary and Q5.
This diagram not made by Dally... Some of member of realstrannik made it. There is few mistakes. Pls pay attention when read it.
verpies
Quote from: fantom on October 07, 2012, 10:47:37 AM
Perhaps, but Itsu just wrote in Reply #264, that he is aiming for this circuit.
If you see mistakes in it, please let him know.
T-1000
Then you might reverse engineer original photos and compare to drawn circuit.
I have attached analysis from my understanding:
fantom
Quote from: T-1000 on October 07, 2012, 11:18:48 AMThen you might reverse engineer original photos and compare to drawn circuit. I have attached analysis from my understanding:
You know... I ask myself. what is point try to copy it 1:1 instead of try to understand how its can work ?
How many years people trying to copy Kapanadze system? What's result?
Why I wrote that BG... Coz every module is easy understand functionality. Then whe can try to prdict what is will be if we connect some modules...
For example main GEN + L1 (in my BG) + (L2+c2) + (L3+load).
U see the ground connected to L1 (Secondary in Tesla coil)... but its shorted by secondary coil of T1.
If Tesla is free, yes there is spray effect for electrons pomp up from the earth... But if it hardly loaded...
May other questions come out. And much more easy to study about it separately first.
Its very easy to assemble system 1:1 ,sure need correct some mistakes (for ex. not connect gate of IRF460 with 3100pF input cap. directly to TL494 outputs)... But in result for sure nothing will work...
If we do not know how to tune the system, reverse engineering of that kind of photos....
Thanks
