0 Members and 2030 Guests are viewing this topic.
woopy
Ok since 2 days i cannot post my pix ??
So i will post in 2 time , first my results and than the pix.
So i tried a lot of experiments with this circuits
1- the choke value , from 56 uH up to 300 uH with each time very different results
2- Capacitors value from 2 uF down to 0.01 uF
3- yoke length , as i have 2 yokes one long about 45mm and one shorter about 30 mm, with both the same winding number and gauge .
4-load value from LED (220 volts ) up to 500 watts halogène.
So i got results from 4.8 kHz up to 250 kHz depending of the config
some time no bipping at all and sometimes strong bipping and some times variable bipping
the out scope trace is  in general a nice sine wave , but it can be very sharp high voltage trace
So i have made always the comparison between 2 loads, one connected to the yoke and one connected to my VARIAC(at the 220 volt grid 50 Hz ) , so i can simultaneously compare the light and the power , to determine an efficiency rate (of course as it is with my subjectivity judgement all my result are not highly scientific , but enough to determine if there is a looping possibility for my level )
And my best result so far is only 75 % , so no looping at this day
I think that this kind of device is very sensitiv to tune. And so long the testers do not use valuable instruments , it  will be very difficult to replicate on a large scale.
It is a pitty that Geofusion has no LCR measurement of the choke and other  measures of his device to aid us to better replicate.
But anyway, i have made my Mazilly ZVS oscillator and learn how to use it, for other Flyback transformer and Tesla coil experiment.
Here i am and will follow the thread with attention
good luck at all
laurent
woopy
OK as the attachment  of this forum not only does not work, but seems to suppress all the text, which is very disturbing  (OH Stefan what have i made wrong  ???)
i try to enclose the pix with an other mean
good night
Laurent
woopy
I just forgot to add a very important point , as per Stivep recommandation, i tried  to increase the gap between the 2 yoke parts, and it seems that the input power decreases when i slightly open the gap, and doing this ,the frequency increases also.
youp a formidable work has to be done on this experiment
and finally the second pix that did not come on the previous post, it is a scope shot with nice sine wave output , taken across the load of one experiment.
laurent
T-1000
Quote from: woopy on October 17, 2013, 05:27:20 PM
Welcome back Laurent :)
I had no problems posting pictures, try different browser?
GeoFusion
Hi all :)
@ menofFather:
Alright 12V. but the bulbs, when you can try 220V bulbs or 120V bulbs on to it and see.
Yes, the Pictures of the schematic that would be of the TK device is very interesting to try out and would be OU for sure.
@ a.king:
Yes the capacitors are used for tuning the resonance between flyback ferrite and Telsa Bifilar coil.
I will try my best to keep up the good work on it and will need help too of you guyz :).
@ Laurent:
Thank you for working on the device you replicated so awesomely. Nice work man:). It's coming out very good and thanks for using Scope and the other testings too see what is happening to it.
also I need a LCR measurement equipment soon.
this is why I need you guyz around to to see what these are capable of. thnk you  again :), finally able to see scoping  of it.
See this one, it's my newer version of it.
Part 1
http://www.youtube.com/watch?v=ocrAX7aBHpc
Cheerz~
