0 Members and 551 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 22, 2013, 01:04:30 AM
   Hoppy, Igor also got some more meters to show both the input, as well as the output readings, in DC this time around.
   It's Not a done deal, for self charging, or self running yet, but slowly getting there.
Some light measuring kit should help his progress down the measurement road.
Hoppy
Nick & all,
I need to eat humble pie. :-[ I decided to measure DC source current on my Royer driven coil setup running at 31KHz using the following instruments: -
Tektronix TX3 DVM (true RMS).
Fluke 325 clamp meter (true RMS).
RIGOL scope across 0.1R shunt resistor.
Digimess bench PSU HY3003-2
Cheapo DVM.
All instrument measurements agreed within a deviation of 100mA between them.
It would appear that the important aspect is that the waveform is sinusoidal (not complex) and at 31KHz all instruments gave close measurements. However, whether this follows at higher frequencies would need to be tested.
GeoFusion
Hi all :),
Srry haven't been active for a while, was busy with many things around the house.
Dad managed to put his time on making a Flywheel Gen. helped him also out and we managed :),  6.5 kW output. for the house.
Now that is done can now get back to my work bench on the advanced stuffs again.
Quote from: NickZ on October 20, 2013, 07:07:57 PM
Geo:
   Maybe using bigger chokes where you are currently using the small ones may help to dissipate and control the heat. Along with putting it where some cooling air from the fans can blow on it. Looks like you're using ferrite chokes where normally the 1 inch size white and yellow iron powdered choke cores are used.
GeoFusion: What happened when you connected the iron laminate step down transformer to the output coil??? What's the news so far?
Hi Nick :)
Yes I should try bigger chokes where I have the small ones now, but, I tried it ones and Blew the circuit, but guessing it was the Wire gauge that also plays a big role in this, If the wire gauge is to big on choke, it can't hold on to the pressure of what is coming back to the circuit and circuit could pop and die. But will try it once more with same wire gauge i used for the smaller ones for sure ;).
I do have a fan for the circuit, does great job holding it cool on one temp :). but yes maybe see how I could hold the toroids cool too.
Yes, Been using Some ferrite chokes and powdered iron core chokes for it, But guessing it's the Iron powdered ones that get so warm till after many minutes hot but they hold the circuit most cool to, so guessing might need a bigger iron powdered toriod core for choke :).
I've seen the post of lastest Igor Vid. He is also using Flyback core and using Same Royer circuit I use :).
http://www.youtube.com/watch?v=FmJSirqpKco&feature=c4-overview&list=UUVesA155Der2tRd5vpyYdJw
As you can see that he measures with such meters on battery without a problem of HF influences with his 2 Fluk meters (=, that is the same way I measure mines, But with my black clamp meter you saw already I could measure even the frequency also as I showed in previous pics.
Oh :) bout the Leminate step up Transformer. I do have step downs but did not try them out yet.
yes when i connect them at the Bifilar output ( blue wires ) i get results that are promising. Awesome output.  I will show this demonstration soon on a vid I promis.   the black main output wires did not test yet. but will to see what it does.
  Hope to buy a new meter today so, upcoming day or so be posting newer info and back on bench with you guyz on the side  ;D.
Btw Check this out, might be useful and gonna try it out soon.
Cheerz
NickZ
  All:
   Ok, looks like we are all working nicely together here.
   Gfusion, glad that you are back with us and also watching Igor's videos now, as well.
  Yes, there are many versions of the Royer or similar type of oscillators. Which one works best for our purpose is still unknow. I was going to make your original circuit, as I love simple circuits, but blew one of the two new TIP 3055 that I was going to use, as my ferrite core has a short in the coils. Don't know if it can be done using one one of them, I may try it to see.
  You can find the 1 inch iron powder (white and yellow) toroid for your chokes, inside old Pc power supplies, if you don't have any. A separate small pc fan will help them also.
  It would be nice to get Igor here with us, if possible. Maybe someone can get a hold of him to suggest it. I already tried to link this site to him on his YouTube page, but it was not allowed.
Hoppy
Quote from: NickZ on October 22, 2013, 11:45:23 AM
  All:
Yes Nick  :)
From Ansis's posts on the other thread, it appears that you may be right that TK has tapped some environmental energy, possibly from lightning!! Hopefully not a crafty connection to that electricity pole on the roadside opposite TK's house, that appeared to interest the camera man, together with the white aerial wire from the fence to a tree in TK's garden! The other clue that Ansis could be on a winner, is that a.king21 told us that his investigating team were told that TK did not like doing a demonstration in bad weather / storm. Too much free energy could be the problem here!  ;D
The Royer oscillator circuit that Geo has posted above is identical to mine. If you decide to build this, use at least 1 Watt zeners, preferably 5W rating. Further experimenting with my setup has shown me that my coil makes an excellent flouro light inverter, so I will be boxing this one up for emergency use during the power cuts that are surely coming in the next year or so in the UK.
