0 Members and 627 Guests are viewing this topic.
NickZ
  totoalas:
  You may also have a problem with your outside Ac grounding rod.  And if you suspect that being the case, you can have it checked by the local electric company, for free.  I know why I'm saying that, especially if your system is 220v. to your house's electric meter or breaker box, not just 110v. Anyway, it costs nothing to have it checked, as in tropical climates the ground connections can become oxidized, or sulfated after some years of use.
totoalas
Quote from: NickZ on October 23, 2013, 09:25:58 PM
  totoalas:
Thanks again
stupify12
Hear me out even a little. Just give a little thinking or analyze this.
This is the secret which Kapanadze ::) :P called simple that everyone will laugh ;D. Everyone the Royer Oscillator or any oscillator is correct and is perfectly fine and has exceeded what really is needed on this device.Let us only aim for a step up transformer capacitor charger on this little electronics.
What are needed?Option A. ;D ;D
1. Two Primary Coil( Primary + Primary= Two Primary) ::)
2.The Two Primary Coil has its own Capacitor, which only ONE terminal of cap and coil is directly connected, The other terminal of coil is connected to the other terminal of Capacitor using INTERUPTER/ Switch MAKE and BREAK. ::) :P
3. The so called MAGIC COIL/Charging Coil= This depends on how many turns you like to charge capacitor so fast. This coil is directly connected to the Two Terminal of the Capacitor with the aid of Semi Conductor DIODE/One Way Valve. Each Primary has its own Magic Coil/Charging Coil. This is what happens if the First Primary discharge its capacitor to the Coil, The Magic Coil of the Second Primary is induced thus charging the Second Primary Capacitor, the operation of the two primary is vice versa. This is what you guys call Coupled Resonance with common sense ;D ;D ;D
4. The Secondary Coil=Loose Coupling/The Third Magic Coil=> This coil purpose is to charge the capacitor of the Secondary/Induced Capacitor Bank,This coil should also possess Diode to charge the Capacitor so fast with the High Frequency Coupled Resonance.
5. Two Ground Rod in the ground separate apart.
This is the last and the tricky part of Kapanadze and other devices. The capacitor first leg is connected to the Ground, The other leg of capacitor is through the second Make and Break/Interrupter to the Output Transformer Primary Coil First Leg=Normal Transformer/Transformer custom made for 60hz power output. The other Leg of the Output transformer Primary Coil is connected to the SECOND GROUND Rod. People this is the right time to Make and Break into 60Hz the Output Transformer Coil.
This is the part that the power output is being completed with the stored energy on the Earth/Ground. The only thing people miss is how to attach the output power to a useable energy for usage.  The Primary and Output Coil is Alternately ON and OFF they should not be together On to not kill the dipole baby. ::) :o
This option A is a bit harder to understand if you really don't get the idea. I know a member here a.king21 knows this one , you should ask some help from this guy, maybe he has already know it but don't get the real idea of the set up. There is also Option B which is always presented by the fame people who always demonstrate it in symposium or convention.
Meow ;D ;D 8)
Hoppy
Quote from: stupify12 on October 24, 2013, 03:37:11 AM
This is the secret which Kapanadze ::) :P called simple that everyone will laugh ;D . Everyone the Royer Oscillator or any oscillator is correct and is perfectly fine and has exceeded what really is needed on this device.Let us only aim for a step up transformer capacitor charger on this little electronics.
Meow ;D ;D 8)
Thank you but your description is not clear enough to fully understand and draw out. Please draw / sketch a circuit schematic.
Nightmare_T34
Akula geve out all his shematics and stuff ! http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/134547-akula0083-soobshheniya.html?limitstart=0
All his messages are gathered in one thread here . Schematics from page 3
