0 Members and 554 Guests are viewing this topic.
totoalas
Quote from: NickZ on October 24, 2013, 04:54:32 PM
  Geo:
   Thanks so much, that's exactly what was needed. I'll get right on it.
   My new yoke is wound and ready to go. Although I could not wind as many windings on it as you have, I'll give it a go, as is, to see what happens with this many windings. The coils  are all wound in the same CW direction (now), the core halves are insulated from each other, and  the clips will be removed once I have it ready to fire up.
  Here's a picture of it. Looks like my other yoke, but it's not.
Hi Nickz  and Geo
Adding an Hv out put  on 1/2  of the primary core   and earth  or ground on the other half  secondary  core seems to increase the output.......   test and see it  please ...
the cores are in direct contact with the hv and earth wires     8) Instead of tape for spacer  I used ceramic ring / neodyne magnet
NickZ
  Yes, Grum, thanks. The 1/2 of the windings have been reversed. I made this error before, and for the reason that you mentioned. As it is easier to start from the center, so that the winding will be centered in the right located in relation to the core halves as mentioned by Geo. The thick white coil windings are not easy to wind, but I've got it right now.
stupify12
Quote from: a.king21 on October 24, 2013, 03:04:23 PM
Benitez essentially uses tesla switches in a novel way.
It's all about high frequency switching as is Kapanadze.
My focus is currently also on the bifilar coil.
Maybe others could help in deciphering Tesla.
According to my understanding Tesla uses the term"self induction" to mean Lenz.
Maybe the EE's could comment on this as a definition would greatly enhance everyone's understanding
of Tesla terminology.
I can easily decipher Tesla 8)'s patents, If you need help just ask me. Be sure to complete the sentence on the term Tesla use for easier deciphering.
Self Induction means Inductance. There are two kinds of Self Induction Tesla 8) cited on his patents.
1.High Self Induction- Tesla always mention this coil, which can be the Coils on his Motor/Interrupter as a Choke Charging Coil. The other form of High Self Induction Coil is Adjustable Inductor. This coil is wound on a laminated core for better magnetic flux build up. I think you already knows how a Choke Coil function on the circuit. The other function of Tesla's Choke is to charge the capacitor when the Magnetic Flux of Choke/Inductor Coil/Motor Coil collapse thus charging the Capacitor with High Electromotive Force=BEMF + EMF.He always mention that if the Inductor Coil  High Electromotive Force couldn't easily charge the capacitor to full, just add more coils- choke,inductor,more and more inductor. This basically means long wound coil on a laminated core, which Tesla like to use the soft iron for better performance.
2. Low Self Induction- This coil means THICK, FEW TURN-3 to 5 turns, This coil is the Primary of the Tesla Coil. The purpose of this Coil on the circuit act as a Resistor with no Resistance at all when the Choke Charging Coil Collapse the Magnetic Field and the current pass through this coil charging the Capacitor.  Lowest Resistance, so the capacitor discharge will be focus on this Coil thus resulting to Impulse Discharge at proper Switching Make and Break Frequency the LC Combination will achieve the Resonance, Tesla don't like to always connect the Capacitor and Coil directly. He alternately charge and discharge the Capacitor to the Primary and Charging Circuit.
You should keep this on mind Tesla always mention that the Primary Coil is Series Connected to the Capacitor with the help of the Interrupter/Make and Break Switch. The LC Combination of Tesla is always SERIES Connected, The Spark Gap will close the circuit of the Capacitor and Coil when you use Spark Gap. In this manner he secure that the capacitor is always full charge when Break the Interrupter which separate the Primary to the Capacitor terminals. I have already tested his High Frequency Generator, the stored energy on the Capacitor actually rises the voltage to the maximum charging of the Inductor/Choke Coil and stay still even it is constantly shorted to the Low Self Induction Coil.
Self Induction - may also mean the ability of the coil to build up magnetic Flux.
There are two kinds of LC Combination cited on his patents.
1. Controlled Amplifying Resonance
2. Freely Oscillating Resonance-the resonance people always talked about. Which is not Tesla way of Resonance.
Meow 8) :D :D ;)
a.king21
I have found that in every coil there exists a certain relation between its self-induction and capacity that permits, a current of given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or, in other words, as though it possessed no self-induction.[/size]
[/size]
http://rpmgt.org/Patents_512340_593138_685012.htm
My question is, "is Tesla referring to Lenz here when he mentions self-induction?"
ARMCORTEX
So the term ''no self-inductance'' according to tesla is the frequency where the admitance of both components cancel out ??
Here is an excellent book I read, alot of work went into making this ipad and search friendly, use it as a reference.
It really is the best book about radio you can find, extremely extremely well presented.
http://www.mediafire.com/download/hj6xg9mab8r27de/radioelectronics.pdf
