0 Members and 45 Guests are viewing this topic.
baroutologos
@ above,
typical behavior of a know it all freshstarter..
The point is not to tell me i am wrong. The point is to show to me and the forum with facts & figures, photos and videos.
If that are too much for you and cannot tolerate some mild critique arisen from your statements.. then See you around :)
Utopia Now
Hello Stupify12
do you have a link to where I can find  your other info ..  I would like to read that :)
Look for my post on the other forum- Energetic forum, Clemente Figuera or Asymmetric Dynamic Machine Thread. I just disclosed a simple Free Energy Device to the man name machinealive, look for his posting on both thread mention here.
Thank you
Utopia
verpies
Quote from: Grumage on October 24, 2013, 05:57:32 PM
I think GeoFusion is right, you appear to have wound your primary in the same direction from the centre!! All you need to do is unwind one half of the white wire and follow the same direction from, say the right hand side through the centre tap.
Unless you are building a regular IMT or a regular stepdown/stepup transformer, IMO the windings should not cover the whole circumference of a divided core.
In energy releasing arrangement, those windings should be split into two semi-circular portions as to expose the core split and permit the clapping of the two core halves by alternating their magneto-mechanical attraction and repulsion at the natural acoustic resonance frequency of the core.  An example of this winding distribution can be seen in the video of this famous device.
dllabarre
Quote from: stupify12 on October 24, 2013, 03:37:11 AM
Hear me out even a little. Just give a little thinking or analyze this.
This is the secret which Kapanadze ::) :P called simple that everyone will laugh ;D . Everyone the Royer Oscillator or any oscillator is correct and is perfectly fine and has exceeded what really is needed on this device.Let us only aim for a step up transformer capacitor charger on this little electronics.
What are needed?Option A. ;D ;D
1. Two Primary Coil( Primary + Primary= Two Primary) ::)
2.The Two Primary Coil has its own Capacitor, which only ONE terminal of cap and coil is directly connected, The other terminal of coil is connected to the other terminal of Capacitor using INTERUPTER/ Switch MAKE and BREAK. ::) :P
3. The so called MAGIC COIL/Charging Coil= This depends on how many turns you like to charge capacitor so fast. This coil is directly connected to the Two Terminal of the Capacitor with the aid of Semi Conductor DIODE/One Way Valve. Each Primary has its own Magic Coil/Charging Coil. This is what happens if the First Primary discharge its capacitor to the Coil, The Magic Coil of the Second Primary is induced thus charging the Second Primary Capacitor, the operation of the two primary is vice versa. This is what you guys call Coupled Resonance with common sense ;D ;D ;D
4. The Secondary Coil=Loose Coupling/The Third Magic Coil=> This coil purpose is to charge the capacitor of the Secondary/Induced Capacitor Bank,This coil should also possess Diode to charge the Capacitor so fast with the High Frequency Coupled Resonance.
5. Two Ground Rod in the ground separate apart.
This is the last and the tricky part of Kapanadze and other devices. The capacitor first leg is connected to the Ground, The other leg of capacitor is through the second Make and Break/Interrupter to the Output Transformer Primary Coil First Leg=Normal Transformer/Transformer custom made for 60hz power output. The other Leg of the Output transformer Primary Coil is connected to the SECOND GROUND Rod. People this is the right time to Make and Break into 60Hz the Output Transformer Coil.
This is the part that the power output is being completed with the stored energy on the Earth/Ground. The only thing people miss is how to attach the output power to a useable energy for usage.  The Primary and Output Coil is Alternately ON and OFF they should not be together On to not kill the dipole baby. ::) :o
This option A is a bit harder to understand if you really don't get the idea. I know a member here a.king21 knows this one , you should ask some help from this guy, maybe he has already know it but don't get the real idea of the set up. There is also Option B which is always presented by the fame people who always demonstrate it in symposium or convention.
Meow ;D ;D 8)
Last night I tried to draw a schematic from these notes but got confused when when you introduced diodes in part 3 so....
COULD you please draw a schematic of what you are describing in the above?
Thanks
DonL
Hoppy
Quote from: dllabarre on October 25, 2013, 11:05:33 AM
Thanks
DonL
I'm glad I'm not the only one to be confused. I also requested a schematic but not seen one yet.
