0 Members and 417 Guests are viewing this topic.
baroutologos
@ Grum,
Thanks for clear cut sketch. It helps me understand a lot. I think those transistors can withstand serious voltage reversed biased from emitter to collector, hence they prohibit to a degree the current "push back to source" hence that increased p-p voltage in relation with the anticipated using MOSFETS or the same transistors with reverse diodes in parallel.
I remember in an royer oscillator i have used series diodes to the FETs but cannot recall increased voltage p-p. Perhaps it was.
Grum, please place one diode (fast schottky preferably 3A nominal) in reverse order in parallel to each transistor (resembling FETs). This way will eliminate the 200 p-p and must lower it to 80 p-p or so. On the same grounds if you place a fast diode eg UF4007 in series with those Mosfets then more than a 200 p-p or so will be noted.
If that happen, then the core ringing increased amplitude oscillation theory is invalid, i am afraid.
Make 1 or 2 test loads if you may. If loading making the 200 p-p drop develop and results in increased input current, again this is the case i am afraid.
ps: Its a nice to see you have a companion black cat in your lab! I have also mine, a white one. Veliakas is the name :D
GeoFusion
Hi guyz :)
@Nick:
Awesome work man. It's lighting the 50watt  fairly :). Yes  for greater output it need more windings on core, the secondary primary also a bit more but not to much.
Ah that is good, atleast she could have heard the ringing of the core :), but as you start putting more load in parallel how I did, you will start hearing it Sing very sharply. Try it :) connect few more of them in parallel.
Oh but not even the 100Watt wanted to light up? That is odd...not even able to burn the filament inside the 100 Watts? hmmm You should make videos of this so we can see :).
I see you tried the adapter of 12V and 500mA to make it work  :D something of good news.
But I will make sure to help you out and manage to make this work as how I have it.
Safety always, although we know these outputs don't shock lol  :)
@Grum:
ahhh Your lab and Lab assistant, Austin is fun to have around ;D. Love cats too. lovely.
Well I still do have my dogs around when I turn on the Tesla coil, they seem to like the Radiant feel thru their bodies hehe.
Lol Yeah , but as it is my design, I still see that it's for all of us for use, I really don't mind  anyone use it. :) It's ment for further research and to better us all on this planet.
I might have visual thoughts when i work with these technologies, I see them working in my head and then implement them, but I need more minds around to make something bigger and better :).
Yes I understand that there are many and many variables of this, but somehow one of these days we will stumble across this and manage to have something totaly OU.
true that, the Inductance does play a big role on this device, use 10 awg on primary ( blue ) coil and 14 on secondary (black) coil.
choke that Nick is using is good, but I also used in the beginning experimentations of winding 19 to 20 AWG around the toroid.
Yes I saw your Scope :P it's awesome and thnx for doing those tests, It made me happy to see that is has some interesting effects
Ah yes some of them are expensive, some of those  LCR meters and sterlings, but yeah I have to get one somehow, sooner or later.. need to see how I manage
Btw again my mosfets I used where IRFZ34N
Cheerz~!
NickZ
   Geo:
   Thanks for your comments. You have been very helpful. I try to post clear pictures so that all can see what I'm doing. I have enough bulbs now to go for 250 watts, or more if possible.
   I'll look for the Z34N Fets, I may have some 260s around here, I'll have to ask the cats, oh, yes, and I have a bunch of them (cats), but could not fit them all in the picture.
  I'll rewind the small choke with smaller gauge wire, and give it a whirl.
I want to make my version as close to yours as possible.
  Remember, that the feed-back path is what will make this the ticket to ride.
   To the Greekster,,,, Nice build!!!  I think that I'm picking up the signal from that huge T-coil from here, as my hair does not want to come down.
  I see that Tesla used to hang out next to his coils, so, he must have gotten some good vibes off of them, as well. At the proper frequency, they very healing, according to him.
verpies
Quote from: baroutologos on October 26, 2013, 06:23:07 PM
What theory?
If you mean NAR then this is not evidence against it.  The pulses caused by it are not nice sinusoids anyway but are very short and powerful needles, having current of several kA.
NAR is an experimental fact that has been replicated in many labs around the world (there is even a paper book about it) but we are quite far from it here yet.  We don't even have the B & f in correct proportions and directions for it to manifest - so far, most Yoke cores here work as parts of regular HF transformers (UU).
Just so we are clear, those labs have not replicated nor investigated the release of energy from matter by acoustic phenomena -  they just did NAR for spectroscopy.
Grumage's frequency doubling is a fledgling evidence of acoustic modulation, however it is far from being optimized yet.  He hasn't even measured his core's fundamental acoustic standing wave frequency, yet.
Good God!  Does everyone on this forum have a cat ?  (myself not excepted)
GeoFusion
@Nick:
You are welcome any time  ;D
Yes posting pics and videos might help so much and telling the details of them as how it should be.
haha cats are funny man, I like them alot. Well atleast one for assistant you know :).
Alright, looking forward to the progress, might be that tomorow will be one posting some new stuff again and sharing :)
Oh yes Tesla coils are very healing :), I often hold on to the tesla coil when it's operating.
arcs of 10 cm long bot grabbing the coil and hold on to it and barefoot, and sometimes without my feet touching ground at all, so elevated.Via ceramics or rummber.
@Verpies: Sadly only dogs now, mines died last 2 years ago, Beauty of white :) called her Snow.
Cheerz~
