0 Members and 468 Guests are viewing this topic.
From other Planet
Small tip for Geofusion Replicators: If  u want to experiment with different choke coil inductances, wind 30-50 turns on 4cm pvc pipe. Then insert ferrite rods/pieces in pipe to adjust the inductance. Can fine tune very easy that way, and also in a big spectrum. I had around 30 till several hundred microhenries range that way.  I made a quick geo replication just for fun. No OU here. But different coil values and caps on primary and secondary side makes definately big difference.
NickZ
  Other planet:
  Thanks for the tip on using the air core with ferrite to tune with, I may try that sometime as well. As I don't have a scope to test for Henries, or Sams.
  I'll also connect the Royer/yoke core set up to my big Akula air core, to see what happens. Similar to Geos second video.
  And, I also do have several of the flybacks, as well, to play with.
  Update:  Although I could not light a 100 watt bulb on the circuit with a 12v 4.5 aH battery, I could light two 50 watt bulbs at the same time. Only dimming slightly the first one.  Although they are not fully bright, yet, it's interesting how this circuits works.
   Geo: what capacitor were you using on the original video, if you can remember.
   I will wind a smaller iron powder choke tomorrow, that is about 3/4 inch wide, using thinner gauge wire. As each detail can be very important. Even the brand of bulbs used, and not just their wattage. As I can light one 100 watt bulb on 500mA, but not the other 100 watt bulb of a different make.
  BTW, no shocks from any part of the circuit or bulbs, even while lighting two bulbs, and being barefoot on a cement tile floor. Sweet!!!
Try that using regular AC current.
No better not to try it... He he.
You are right on the edge of having a viable wireless power transmitting system with your Royer oscillators.
http://www.youtube.com/watch?v=gi-hl2W86yk
stupify12
Hello guys. How are the things going on? Can I ask dumb question?
@Everyone. How can we achieve a design of inductor that the induced currents of Primary is IN PHASE to the secondary? Any ideas and opinion are greatly appreciated ;D ;D
Does In Phase means no opposite magnetic field created on the Secondary Coils reflected to the Primary? ??? If does not reflected to the Primary how can we achieve such design?
The  answers of this question will lead to the right answer on Kapanadze quote" The secret is simple that you will laugh" " I absolutely needed Bifilar Coils to Run this device".
baroutologos
Hello Verpies,
Quote from: verpies on October 26, 2013, 08:10:12 PM
What theory?
If you mean NAR then this is not evidence against it.
No it was a theory about ringing means more energy than.. inputed. it was mentioned in a private message.
Grumage's frequency doubling is a fledgling evidence of acoustic modulation, however it is far from being optimized yet.  He hasn't even measured his core's fundamental acoustic standing wave frequency, yet.
How can we measure this fundamental accoustic resonance frequency? Any suggestions? The sand? :P
Good God!  Does everyone on this forum have a cat ?  (myself not excepted)
:D, there are perfect animals for workshops. usually they sleep all time :P
