0 Members and 133 Guests are viewing this topic.
NickZ
  Hoppy: No, I did not try the resistor, yet.  What value would you think is best to try?
I'm testing the fan connected on my pc to see if it really does work, first. Since it was mentioned that is should work just connected to the 12v battery, but it won't, so far.
  GeoFusion: Any news on your feed-back path, yet???  As that's the most important point.
  a.king thinks that Igor should be able to feed back to input with the higher output from the very efficient Induction heater oscillator's output. But, the problem is that the oscillator won't work if the input comes from his current inverter, which is still the hang up. I'm waiting for further results on that as well. Although not an easy fix... but, the idea is to toss the battery and just use caps, or buy or have custom built induction heater circuit that runs on DC. I hope that he can do so.
  Edit: Geo: Great news about your feed-back path, and all other information above.
Please check on how long the (smaller 12v) battery last when on the feed-back circuit, and how it does with the different loads.  Thanks.
  Here is Igor's latest tests. Please check them out.
    Tesla-ish:
   http://www.youtube.com/watch?v=sDPFGG-7G9E&feature=c4-overview&list=UUVesA155Der2tRd5vpyYdJw
  http://www.youtube.com/watch?v=FmJSirqpKco&list=UUVesA155Der2tRd5vpyYdJw
Hoppy
Quote from: NickZ on October 28, 2013, 03:54:52 PM
Nick,
Try 100 ohms and a 10nF cap in parallel with the 10uF. If it does not work on a 12V battery, then its busted!
Grumage
Dear Nick and all.
Nick if you thought the new Akula0083 schematic was complicated?? Well take a look at this form the DIGITAL age!!  ;D
https://www.youtube.com/watch?v=0_fTQvEnhvQ
I have also been "Harping on" about not being able to self loop those induction heater circuits with inferior inverters!! I think that the only way to run one would be with a pure sine inverter. Most of the cheaper units put out a Square wave!!
Cheers Grum.
GeoFusion
Nick :
I might have Figured out what i need, but have to buy the parts, yet money plays a big role on this on  :-\.
thought of using DC caps in Farad range around like 1000 to 2600 Farad as a storage and to form 12V atleast. Like those Ultra caps goldmine sold some time ago. but uhm, Was thinking to able to make the Circuit of the newer one receiving around 12V~ to 200V DC input, because mines works now on 24V as you saw, but can go up to 36V Dc only and gives power eq. to 3 kW .
But the new concept should be able to get me alot more Load.
My visualisation that Would or Will work If I adapt it on what I have now.
connecting one 12V battery to inverter, 12-120Vac and Full bridge rectify it, and add to a powerful Royer (cooker)  circuit, Massive energy at output coil.
Stepdown transformer at bifilar or Variac lower the voltage . Rectify again, to DC caps to charge and all the way to circuit again, able to see  the Self Run there :P
@Grum:
Thnx for the link posted very good one :).  There are many ways how to produce without grounding
We should take examples of out brothers and sisters from other planets, how they manage without grounding but using the Eather :).
Cheerz~
Hoppy
Quote from: GeoFusion on October 28, 2013, 04:27:34 PM
Nick :
I might have Figured out what i need, but have to buy the parts, yet money plays a big role on this on  :-\ .
Hi Geofusion,
Is that 3KW continuous or instantaneous?
